New frame - Do I ne...
[Closed] New frame - Do I need a new chanset?
Old frame has a 72mm BB, new one is 68mm. I have an old Shimano M440 Cranset fitted to the old frame - can I change them across?
If not I presume I would need a new BB so would I just be better off getting a new Deore crankset from CRC for £50?
Going on a Maxlight XC frame.
Posted : 10/11/2009 8:36 pm
 PJay
You'll need a new bottom bracket to fit the 68mm shell but with the same axle length as the current one (probably 113mm or 118mm). You should be able to pick up a new BB reasonably cheaply (I assume it's a square taper) but a new Deore HTII crankset will include a HTII BB as well as the crankset.
Posted : 10/11/2009 8:44 pm
You can change them but why? you'll need new bb anyway. And how are your rings!? If they're Knackered you'll need new casette & chain probably too!!
Posted : 10/11/2009 8:46 pm
Deore Crankset comes with BB I think "dusty trails".
Anyone know if there will be a significant weight difference between my olf M440 and a new deore crankset.
How do I know what axle length it is?
Posted : 10/11/2009 10:00 pm
Take out the BB and measure it- it'll be either 113mm or 118mm more than likely.
A new BB is £25 RRP (not sure who's doing it for what), and you may as well go for a new chainset as you'll get new rings and have more of a new bike feel.
Posted : 10/11/2009 10:15 pm
