new chainring
[Closed] new chainring
[#3884754]
I need a new middle chainring to go on to my deore 590 chainset. Will any 4 bolt chainring do the job or does it need to be an exact replacement? Pls help.
Posted : 18/04/2012 1:27 pm
It needs to be a 4-bolt compact made for HTII or you will be busy with a file.
BCD is 104mm, but get the smaller diameter platform for HTII.
Do not buy a composite ring (SLX, XT or XTR) as these only fit those cranks without grinding, and I do not recommend that.
Shimano steel replacement will be perfect.
Middleburn are good (but expensive), and get the right (HTII) one.
PaulD
Posted : 18/04/2012 1:33 pm
That's great PaulD, so as long as its compatible with a HT11 crankset it should be ok.
Is it due to the fact that the bottom bracket gets in the way?
Posted : 18/04/2012 2:29 pm
it's only the inner where the BB gets in the way. The old octalink granny rings had larger lugs.
You just want a normal stamped ring like this:
Steel is a bit heavier but will last longer.
If you get one of the composite reinforced rings like on SLX, XT and this years deore then you will need to file a bit off the arms to clear the bulky composite bit.
Either go for a deore or LX ring if going for shimano.
Posted : 18/04/2012 5:10 pm
