New carbon post, ol...
[Closed] New carbon post, old steel frame - 2 questions....
 DT78
Due to the 10% CRC discount.....I have a carbon post on it's way...
Now...
1. Any suggestions on cleaning out the inside of the seat tube? It's got years of copperslip, grease and rust residue. I can only get to the top few inches....
2. Should I also get myself some carbon paste stuff or is seizing only really an issue with alloy/carbon?
Posted : 05/10/2010 11:00 am
Good LBS might have a seat tube reamer to ensure its clean and perfectly round before you fit the post.
Posted : 05/10/2010 11:27 am
Rag down the inside with a rod/bar.
No need to ream if post goes in OK.
Posted : 05/10/2010 11:28 am
Get a 500mm or so length of m6 threaded rod or similar, couple on nuts and washers from b&q or your local fastener place. Then sandwich a square of scotchbrite between the nuts and washers, put the other end In a drill chuck and clean away.....
Posted : 05/10/2010 12:39 pm
Prob a good idea to use the scotchbrite thing and add in some degreaser to help break down any remaining.
Prob worthwhile taking out your BB first and then give it a good rinsing with it.
Posted : 05/10/2010 1:06 pm
