Need help with tube...
[Closed] Need help with tubeless - ZTR Olympic on Racing Ralph/Nobby Nic
 JxL
Finally bought most of the parts for my singlespeed build, and had a go at installing a tubeless system without any luck.
I used the method shown on Stans website - using soap around the tyre, and pumping with a track pump. However as it is a brand new tyre[s] there are gaps between the rim and tyre, and air simply escapes it. I do not have a compressor.
Should I put some extra rim tape? Now it has the yellow one. The tyres went on quite easily without the need for tyre levers.
Thanks!
Posted : 18/06/2009 2:06 pm
Some door frame sealant in the well of the rim helps
Posted : 18/06/2009 2:11 pm
Inflate the tyre with a tube in it. Leave for a while so the tyre shapes to the rim. Remove tube and do the tubeless fandango.
Posted : 18/06/2009 2:15 pm
 JxL
Good idea sslowpace - off to try it ๐Ÿ™‚
cheers
Posted : 18/06/2009 2:28 pm
i found with ralphs a couple of weeks of riding them had really let them take the shape of the rim.
total faff to try and get up when new - when they were worn in - went up on my own with a track pump - in less than one beer.
Posted : 18/06/2009 2:52 pm
Dont forget to leave the inner tube in as well you crazy fool!!!
friday thinking about Lee Quarry as a possibility you interested?
Parts ordered for suspension bike so if they arrive tomorrow you can have a play on it - e-mail me.
Posted : 18/06/2009 3:01 pm
I just go around the tyre pulling both sidewalls out, never failed yet on about 10 pairs of Schwalbe tyres.
Posted : 18/06/2009 3:07 pm
