As title really.
I can't seem to be able to find the geometry chart for the 2010 Turner 5 spot.
I can find the 09 and 11 models but not the 10.
Any help would be great.
Steve
This should have the info you require AFAIK the 2010 was basically the same as 2009 but with the revised seat tube gusset ( burrito v taco )
The 44 mm head tube and slightly slacker head angle was on the 2011 frames.
They also ran the rear mech cable through a hole in the rear triangle in 10 or 11 can't remember when it was introduced. The 2009 rear triangle had it cable tied to the side. Wasn't a problem really.
Bit of a turner geek here ๐
Edit didn't you sell yours?
Yep sold mine.
Just wanted to compare geometry.
I believe the 10 was longer than the 09 but shorter than the 11.
Longer where? Top tube?
I don't think so, could be wrong. Think they only made very minor changes.
I went from a 2009 to a 2011 both in medium. They were very similar.
Its alright Ive found it.
cheers
Steve
Was there much difference in length?
Not really to be honest.
Suprised at how short the reach is though !
I think turner used to recommend a 90 mm stem which wasn't unusual for the usa. Always ran mine with a 75 mm stem on a medium. Tried a large frame with a 50mm stem could have riden either really I'm 5'8.
Had a 2012 version with 150 pikes, that was a superb trail bike. On a Burner now ๐
