Need a tiny cable s...
[Closed] Need a tiny cable stop for dropper post conversion
Looking to adapt a gear cable to use with Thomson Covert dropper in conjunction with Spesh SRL lever - the latter being designed to use the end of the gear cable that the dropper already uses.
I've seen a solution that would work, A la:
[URL= http://i968.photobucket.com/albums/ae168/keepitsteel/image_zpsfxr1zmfp.pn g" target="_blank">http://i968.photobucket.com/albums/ae168/keepitsteel/image_zpsfxr1zmfp.pn g"/> [/IMG][/URL]
And I found another thread where a mechanics used one of these for a home brewed solution. Albeit this was for a trigger shifter conversion:
[URL= http://i968.photobucket.com/albums/ae168/keepitsteel/image_zpsvcsg2mo5.pn g" target="_blank">http://i968.photobucket.com/albums/ae168/keepitsteel/image_zpsvcsg2mo5.pn g"/> [/IMG][/URL]
Anyone have any experience of this and know where to buy a similar cable stop? Ideally it would fit within the original recess on the lever but as that is a really small component I'd imagine a more realistic solution is as per first image above.
Posted : 28/03/2016 9:53 am
KS Dropzone posts use a similar cable stop to hold the cable in the lever at the top of the post. Is bigger than a normal cable stop but not by a massive amount.
South Coast suspension carry spares.
Posted : 28/03/2016 9:58 am
Search on "cable grub screw" on eBay.
Posted : 28/03/2016 10:02 am
Something like a "shaft collar" for RC-models should come in appropriate sizes.
Posted : 28/03/2016 10:57 am
Nice shout, I'll google that too... Could be a risk though
Posted : 28/03/2016 11:29 am
Aye, don't forget the RC bit (maybe don't just google "shaft model").
Posted : 28/03/2016 12:13 pm
I converted a spare machanical level I had with the metal internals of a small electrical connector block - feed the cable though and tighten the grub screws.
Edit- having looked in more detail at the photo up there^^ you may have to cut it in half to work (and maybe trim the grub screw off once tightened......
Edit 2- I will not be held responsible for any blood-stained carpet if this goes wrong.....
Posted : 28/03/2016 2:29 pm
