I currently have a smart lunar r2 but it has stopped working so need a new rear light.
I do a lot of riding on dark country lanes so need a good/bright rear light!
what can you recommend that isnt going to break the bank ?
cheers
Steve
Moon Shield, I've got two.
[url= http://shop.18bikes.co.uk/products.php?plid=m15b0s413p1671 ]http://shop.18bikes.co.uk/products.php?plid=m15b0s413p1671[/url]
These things do me fine...
[url= http://www.ribblecycles.co.uk/sp/road-track-bike/Electron-Rear-7-Ultra-Bright-Wide-Angle-7-LED-EHP226/ELECLIGH399000000000?utm_campaign=Googlebase&utm_medium=organic&utm_source=Googlebase ]http://www.ribblecycles.co.uk/sp/road-track-bike/Electron-Rear-7-Ultra-Bright-Wide-Angle-7-LED-EHP226/ELECLIGH399000000000?utm_campaign=Googlebase&utm_medium=organic&utm_source=Googlebase[/url]
You need two for when one breaks down.
They are bright lights but the first light breaking didn't stop me buying a second though.
They're good because the rubber mounting strap goes anywhere, they're possibly too bright and they're USB chargeable.
The weak point is the rubber bung for the USB port. Moisture will get in but I had been using my first light without mud guards so the water was being thrown directly up onto its underside which is where the USB port is located. The light basically needs this port to be behind a more watertight screw-on lid or something.
The charge lasts about a couple of hours. Enough for two days worth of commutes in my case but can easily be charged at work.
Moon Shield here as well. Valid point re the USB port, but mine's lasted very well through the last year and that was more than wet enough!
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=29543 ]Blackburn Mars 4.0[/url]
I have one on the back of all my bikes, stupidly bright with side LED's
Another vote for the shield here. Bung went A.W.O.L. within a month; tried electrical tape, but now use a blu-tac "plug".
Bought a few Planet-X ersatz smarts @ £2.50 per (thanks, brant) and they're a great back-up.
They're good because the rubber mounting strap goes anywhere, they're possibly too bright and they're USB chargeable.The weak point is the rubber bung for the USB port. Moisture will get in but I had been using my first light without mud guards so the water was being thrown directly up onto its underside which is where the USB port is located. The light basically needs this port to be behind a more watertight screw-on lid or something.
Those USB covers ports are a bit naff granted, but I rode 34 hours the other week with mine last week, and it lashed down for most of that time. They still work fine.
No way they are too bright.
Here you go,phaart lights, a fiver, and as good as anything
http://www.planet-x-bikes.co.uk/c/q/lights
They are fantastic for the money,equally as good as my half watt smart one.
houndlegs - Member
Here you go,phaart lights, a fiver, and as good as anythinghttp://www.planet-x-bikes.co.uk/c/q/lights
POSTED 6 MINUTES AGO # REPORT-POST
On-one's dual 0.5 watt copies of Smart's are excellent for the (very little) money. Very, very nearly as bright. I went back and stocked up on a few more. Their copy of the Smart R1 isn't as good/bright and has a limited cycle of the LEDs
I'm using a Lezyne Femto .. really nice discreet and powerful light only £13
I commute, and always have a couple of rears, most are good. However, I do recommend a 'Bones' led rear from On-one to attach to your helmet, colleagues remark how well they can see me. Cheap as, good service too.
I recently purchased an Exposure Flare; quite bright. Well made bit of kit with reasonable side visibilty. The flash mode is rather nice as it doesn't fully turn-off, just dims the beam a bit and pulses the high output setting a couple of times a second.
I've got an Exposure Flare, Moon Shield 60 and Cateye ld610. Moon wins hands down closely followed by the Cateye. Had reliability problems with the Flare (won't stay on flash mode) and eats batteries.
Hope district? Can be seen from orbit.
I've had a [url= http://shop.18bikes.co.uk/products.php?plid=m15b0s413p1761 ]Moon Sport[/url] for a few weeks & it's superb. Very bright, long lasting & rechargeable too
Very pleased with this
http://www.ebay.co.uk/itm/Fluxient-5-Led-rear-light-laser-beams-The-ultimate-safety-light-batteries-/300841751558?pt=UK_SportsLeisure_Cycling_Bike_Lights&hash=item460b90d406
Cars definitely give me more room.
Where's it going to mount ?
You want too bright. [url= http://store.dinottelighting.com/300r-red-taillight-with-built-in-battery-p111.aspx ]http://store.dinottelighting.com/300r-red-taillight-with-built-in-battery-p111.aspx[/url]
I've got the 140 lumen version and that is bright.
dales rider, going to mount on the seatpost at the bottom as its a dropper post.
Are the ones with lasers built it legal??
What about this? 500 lumen for £33. The only thing is the battery's are not built into the light, also I'm not sure if it includes a battery pack
http://www.candb-seen.co.uk/bikehead-lights/rear-lights.html
out of stock mate
Sorry mate didn't see that. Had a few beers
dales rider, going to mount on the seatpost at the bottom as its a dropper post.Are the ones with lasers built it legal??
Had many a light over the years and my favourite at the moment is the Lezyne Mico Drive it is easy to take on off doesnt use much leccy and is bright, also USB charger. I also use a knog clipped somewhere on my clothes, or a Cateye which I mount on a seat stay.
Technicaly LEDs are illegal as the law mentions something about a Filament lamp, which applies to all vehicles. So some modern cars break the law. As for flashing that is legal now
Moon Commet just replaced waterlogged light. So far, so good.
I'm going to say that's balls.
Knog Bloomers USB's are also a good light.
Great if your light gets covered in mud etc.
I say Moon Shield also. Mine is on its second winter of pretty heavy use. Battery lasts longer than (someone) mentioned above, I regularly go over 4 hours use on mine. I think it is meant to last 5 1/2 hours.
Incidently, I have a Moon X300 as my helmet light. It is outstanding also.
Weather proof, USB chargeable, super bright Knog Blinder
out of stock mate
It's not!
fourbanger - MemberTechnicaly LEDs are illegal as the law mentions something about a Filament lamp, which applies to all vehicles. So some modern cars break the law. As for flashing that is legal now
So back it up with something more intellectual then !
Or just in case you cant extracts from the regs
Pedal cycle
Type of lamp Schedule Exceptions
Rear position lamp Schedule 10: Part I None.
Filament lamps14.—(1) Where a motor vehicle first used on or after 1st April 1986 or any trailer manufactured on or after 1st October 1985 is equipped with any lamp of a type that is required by any Schedule to these Regulations to be marked with an approval mark, no filament lamp other than a filament lamp referred to in the Designation of Approval Marks Regulations in–
(a)regulation 4 and Schedule 2, items 2 or 2A, 8, 20, 37 or 37A; or
(b)regulation 5 and Schedule 4, item 18,
shall be fitted to any such lamp.
(2) Where any pedal cycle manufactured on or after 1st October 1990 is equipped with any lamp that is required by any Schedule to these Regulations to be marked with a British Standard mark, no filament lamp other than a filament lamp marked with the marking indicated in the British Standard specification for Filament Lamps for Cycles published by the British Standards Institution under the reference 6873: 1988 namely “B.S. 6873” shall be fitted to any such lamp.
Dales, which version of the RVLR are you quoting. Are you quoting the original 1989 version or its subsequent amendments?
There's a good summary [url= http://www.ctc.org.uk/cyclists-library/regulations/lighting-regulations ]here[/url]. According to the summary the 1994 amendment of the RVLR removed the filament bulb design restrictions, which is just as well as I've a couple of LED lights that have BS6102 stamped on them.
Edit: I found [url= http://www.legislation.gov.uk/uksi/1994/2280/regulation/8/made ]The Road Vehicles Lighting (Amendment) Regulations 1994[/url]:-
Filament lamps on pedal cycles
8. Paragraph (2) of regulation 14 shall be omitted.
Sum - MemberDales, which version of the RVLR are you quoting. Are you quoting the original 1989 version or its subsequent amendments?
So 2003 amendment seems to have sorted out the filament lamp, not noticed that. Mind that's the problem with legislation easy to miss the important bits.
That aside it would seem that if you were involved in an accident/incident you would have some contributory negligence, unless your lights met the 1989 regs and all subsequent amendments.
So check your lights and if they are not stamped [url= http://www.bzwxw.com/download/41/BS%206102-3-1986%20Cycles.pdf ]BS 6102-3[/url] they are illegal 😀
Also interestingley your batteries need to last 10 hours 🙁
Apology accepted.
Cheers all just ordered a moon !!
