bought a pair of these forks
http://www.jejamescycles.co.uk/rockshox-reba-29er-rlt-dual-air-fork-15mm-maxle0mm-id75234.html
just wondering what hub to get as the hope pro 11 says its a 17mm axle and these forks are 15mm
[quote=windjammer ]bought a pair of these forks
just wondering what hub to get as [b]the hope pro 11 says its a 17mm axle [/b]and these forks are 15mm
โ
I'm sure it isn't
http://www.chainreactioncycles.com/Models.aspx?ModelID=60984
Hope pro II's are convertable so any can be converted to 15mm, but if your buying a new one get the one above with adaptors pre installed.
Your pro 2 just needs converting just ignore 17 mm
Pro 2 Evo's are a 17mm REAR axle. The fronts are 20mm and will fit any fork with the correct adaptor (15mm in your case).
