need a fast, slotty...
[Closed] need a fast, slotty drop-out 700c machine, suggestions?
I want to replace my Spesh SIrrus commuter machine, with something else.
I need something stiffer, as i'm a bit 'big' and the frame flexes quite a bit when i hammer it.
I want it to run a alfine out back, and would prefer slotted drop-outs. Although would consider concentric BB if they are reliable.
Ali or Carbon, and preferably not too sit-up-and-beg.
Something longish but not too high. I have the arms of a baboon, and legs of a hobbit.
It will do some road/country miles, but mostly be a commuter.
So, if a Pompetamine was made in Alu/carbon that would be just right i reckon.
Any suggestions, as i dont seem to be able to find anything that fits this bill.
Frameset only, as i have wheels/700c 'project two disc fork' to go on it.
whaddayareckon????
Posted : 27/03/2012 1:06 pm
oh, and it's going to have to be Canti back brake.... or disc.
Posted : 27/03/2012 1:20 pm
If you find it, let me know - considering going custon alu or titanium to get a lighter equiv. to my Pometamine frame, with the geometry slightly tweaked.
Posted : 27/03/2012 1:24 pm
Pick the right cog sizes and you can run a vertical dropout frame without a tensioner. It's not hard and any LBS shoul be able to do that.
Posted : 27/03/2012 1:27 pm
Taking that a step further (and because it going to cost a bomb anyway), my thinking is to go vertical drop out and EBB if I go custom, so I can just swing the rear wheel in and out without having to retention the chain in the event of a rear flat.
Posted : 27/03/2012 1:32 pm
bm0p700f
- true enough. I just wanted as little faff and inflexibility as possible. Maybe worth considering tho'
Cheers.
bristolbiker
- it's not the weight i'm concerned about, it's just that i dont really like noodley feeling steel frames.
Posted : 27/03/2012 1:37 pm
Buy the non slotty frame you want and use a tensioner? They look poopy but work a treat ime.
Posted : 27/03/2012 1:55 pm
I'm by no means big, but I wouldn't describe a Pompetamine as "noodly" - anything but infact, to the point of feeling dead. This is fine at 6:30 in the morning when you just want a tank to steam-roller through everything on the way to work but it really is the most lumpen and uninspiring bike I've ever had - I have a very 'love-hate' relationship with it.....
Posted : 27/03/2012 2:04 pm
I reckon its just that i have never really liked steel bikes. I find other materials just a bit more "direct' without being overly harsh.
Uninspiring is the word i would use for every steel bike i have owned/tried.
Posted : 27/03/2012 4:58 pm
 Sam
Can't help much except to say a concentric bb is not going to help much in tensioning the chain.
Posted : 27/03/2012 5:06 pm
OK, thanks Sam. Are they not really up to much then? It's obviously the more complicated solution, and therefore likely the most inferior.
Posted : 27/03/2012 5:15 pm
he's being pedantic, all standard BBs are concentric, what you want is an eccentric BB.
Posted : 27/03/2012 5:30 pm
AH yes..... that'll be the one i was meaning.
I am happy to stand corrected and to be corrected by a pedant too! After all i would not be lurking on this forum if pedantry wound me up too easily.
Thanks Pinches. Thanks Sam.
Posted : 28/03/2012 5:38 am
456 carbon with horizontal dropouts and road wheels ๐Ÿ™‚
Posted : 28/03/2012 7:07 am
 Sam
Yes - sorry for the pedantry. Good eccentric bottom brackets work very well, and IMO are much simpler in use than a horizontal dropout when used with disc brakes. It's why I use them on my disc frames, though they are all steel so probably not of interest.
Posted : 28/03/2012 11:25 am
Edit: Typing on phones sucks......
Posted : 28/03/2012 5:47 pm
Well that does look quite interesting Brant. I will check the dimensions, but I'm not sure about MTB geometry on the road machine. I don't know what difference if any I'll notice as I have only really had mountain bikes. I'll be running a standard mtb stem and bars.
With a 700c specific fork I reckon the head angle will sharpen up a bit, which would be a good thing in my book.
Any concerns getting the 700c rear into the frame comfortably? And how do the replacement drop-outs work? Is the disc mount on the dropout plate?
Posted : 28/03/2012 5:52 pm
