need a 96mm BCD nar...
[Closed] need a 96mm BCD narrow wide chairing north york/ne
just about to finish my hardtail build off , tried to install 104 chain ring and it doesn't fit.
superstar do them but have closed now till 2nd and chain reaction have the oneup 96 rings but have stopped delivery now till the 2nd
I'm based in north yorkshire/ north east does anyone have one spare? can collect and pay
Posted : 30/12/2018 12:37 pm
no one?
Posted : 30/12/2018 2:43 pm
 poah
Tried a bike shop or amazon?
Posted : 30/12/2018 3:15 pm
Stif?
Posted : 30/12/2018 3:47 pm
Sadly not if I did it'd be yours
Halfords not an option ?
Posted : 30/12/2018 3:55 pm
I have a new neutrino components 30t oval m7000/8000 that I can post 1st class tomorrow for £20 in the unlikely event that's any use- PM if interested.
Posted : 30/12/2018 5:32 pm
it is the symmetrical version not the xt and slx specific ring
it is needed asap and getting it delivered from any where wouldn't be until the 4th as everyone is closed down
I have a asymmetrical slx ring from a damaged crank which is 96mm as well
two of the bolt holes line up could I run it with just two bolts? it would probably come loose quick
Posted : 30/12/2018 6:13 pm
I think you may be right! Certainly would produce some unexpected ovality...
Which crank is it going on?
Posted : 30/12/2018 6:15 pm
it's going on a 3×10 deore crankset
I assumed it was 104 and ordered a chain ring to fit but got a shock when I tried to install it
Posted : 30/12/2018 6:19 pm
Coming loose is ok in some sense- you just tighten them up. The problem is a strong rider could probably strip the threads if there are only 2 bolts. I don't think I'd do it.
Posted : 30/12/2018 6:21 pm
 poah
Standard 96 by the looks of it
Posted : 30/12/2018 6:24 pm
oneup do one but none of my lbs stock it
Posted : 30/12/2018 6:28 pm
Westbrook in Stokesley seem to be open 'til dinnertime tomorrow
Posted : 30/12/2018 6:29 pm
they have 96mm chairings on their website too but I don't know if that's what they have in stock or to order from suppliers
Posted : 30/12/2018 6:37 pm
You could try ringing them in the morning? Standards (or lack of them) suck big time!
Posted : 30/12/2018 6:41 pm
I'll be ringing them and my other lbs that were closed today but are open till dinner tomorrow like Westbrook
it seems like a pointless standard too as I can't see any advantage over 104 on a triple
Posted : 30/12/2018 6:45 pm
I have an unused 96bcd 36t oval n/w in North Leeds, might be a bit far for you
Posted : 30/12/2018 8:08 pm
Think laterally and borrow a full chainset instead.
Posted : 30/12/2018 10:17 pm
Near Newcastle, but i have a race face 1x10 with 24mm axle you can borrow.
Posted : 30/12/2018 11:23 pm
if it's 24m on axle it'll work with shimano bb won't it?
Newcastle might be a bit far though I will send you a pm
no luck at both shops when I rang up so borrowing/buying a new crankset might be only option
Posted : 31/12/2018 11:19 am
