NBD - Downhill buil...
NBD - Downhill build
So took the plunge and decided to build my daughter a DH bike.
After a (very) generous offer from @dc2.0 of a frame for a good price it seemed like a no brainer to give it a go.
IMG-20240522-WA0001
One 2018 Commencal Fury 👍
Rear shock has gone for a service at J-Tech.
After looking around for components I'm picking these up at the weekend while we're down at the MIJ race:
Screenshot_20240601-141204~2
2019 X-Fusion RV-1 DH Coil
Screenshot_20240601-141230~2
2019 Kore Torsion DH wheelset
I've got some 4 pot brakes, getting bars & stem off a mate, so just need to source the following:
- Tyres (27.5)
- Crankset & PF BB
- Group set (think I've found 7spd X0 DH)
- Chain guide & bash
And think that's about it.....
Any recommendations for "all round" DH tyres (was thinking Maxxis Assegai & Minion DHR),, and a Crankset?
Will update as we build.
Posted : 04/06/2024 9:30 pm
Any recommendations for “all round” DH tyres (was thinking Maxxis Assegai & Minion DHR),, and a Crankset?
Noice. That's exactly what I'd run, or a Conti Kryptotal combo. Crankset I'd go for something bombproof and fire and forget like Hope.
Posted : 04/06/2024 9:33 pm
I do love a DH bike.
Before I bought cranks I'd splash out on a threaded conversion for that pressfit bottom bracket so you're not constantly replacing creaky, plastic BB's.
Then for cranks whatever Shimanos are on sale.
Posted : 04/06/2024 9:44 pm
finners and finners reacted
Every bike is a down hill bike if you're at the top a the hill.
Posted : 04/06/2024 9:59 pm
As soon as I saw title, I was audibly going oooooo! What could this be I wonder?
Lovely colour stealthy will look.
Forks came on my Fury and x fusion are great performing. I run Metric RC damper on my mini DH SS AGRO fully. They're unreal comfy
Posted : 04/06/2024 10:20 pm
Deffo buy a standard bearing WMFG BB as it will last then and be a spot on fit from get go.
Then some cheapy 2nd Saint cranks.
Microshift for gearing is great shifting ime and vgvfm.
Stickier compound rubbers the better obvs.
Posted : 04/06/2024 10:25 pm
Might even not need change the coil spring as standard should do just fine . X fusion stated I should've been on an x firm though would've only bought a firmhad they been in-stock at time
Posted : 04/06/2024 10:27 pm
Thanks all.
Not sure whether to go for full DH casing or DD on the Maxxis as she's pretty light.
Looking around the DMR Axe cranks seem to be on offer at the moment.
Posted : 04/06/2024 11:06 pm
DD should be fine though no experience only DH casing as I was heavy heavy.
Yh DMR axe cranks I nearly bought once, look like saints so yh 👍
Posted : 05/06/2024 12:27 am
Be aware though that with DMR cranks, have to buy ring and BB separately or that's what the bastad lbs owner told me. I ducked off at that point as he wanted RRP.
Posted : 05/06/2024 12:28 am
dirkpitt74, zerocool, dirkpitt74 and 1 people reacted
I'd go for Supergravity Magic Mary front (Ultra Soft purple) and whichever Supergravity Schwalbe tyre appeals (Soft orange) for the rear, Big Betty is fine.
Posted : 05/06/2024 9:25 am
Yh MM is a good shout up front. I run soft in super trail though if it were on a DH rig then deffo ultra soft.
Just don't expect it to last that long
Posted : 05/06/2024 9:30 am
In a PF92 bottom bracket shell, which that one is, I'd avoid any crank with a 30mm axle (which includes the DMRs). There just isn't space for the bearings and they inevitably fail quickly. Saints, Zees and possibly the RaceFace Chester are your best bet.
Posted : 05/06/2024 9:39 am
dirkpitt74, zerocool, zerocool and 1 people reacted
Thanks all, have found a Zee/Saint bits that I'll collect in the next couple of days too.
So cranks are standard Shimano spindle diameter.
Which is the correct Wheels Manufacturing BB that I need as I'm getting a bit confused looking at them! - need PF30 / 83mm with Shimano axle.
Tyres I'll have a look around and see what I can get.
Thanks
Posted : 05/06/2024 1:25 pm
V good point Munro. Bravo 👏
24mm axle though don't quote me ...
WMFG should have a contact form - GETONIT! 😁
Posted : 05/06/2024 1:30 pm
Grid Gravity T9 Hillbilly / Butcher could be a good bet too. Or Cannibal.
Posted : 05/06/2024 2:44 pm
Regarding BB's it BB92 Press Fit, not PF30.......
I've come across this from Token:
Token BB
LINKY
Posted : 05/06/2024 3:13 pm
For tyres I'd still be going for DH casings, I was 10st soaking wet in armour and standard cases would just result in ruined runs.
Don't get hung up on DH drivetrains, a 9sp road mech and cassette did fine BITD, you'll still have a chain guide and NW ring to keep it together. My Tues has a 10sp Zee and road cassette because that's what it came with.
Posted : 05/06/2024 4:04 pm
dyna-ti and dyna-ti reacted
Thanks for the advice.
Picked up a rear mech (thanks @weeksy ) and wheels & forks from the MIJ Downhill race yesterday, most other parts have either arrived (soft fork spring, cranks & shifter) or "in the post" (Token BB, Headset, pedals & grips) so hopefully by the end of the week I'll have the majority to be able to start the build.
Posted : 10/06/2024 5:21 pm
Right then, here's the final build spec:
2018 Commencal Furious
Reach adjust headset +6mm
Token threaded PF BB92 bottom bracket
X-Fusion RV-1 forks with Soft spring
Kore 27.5 wheels with Conti Kryptotal F/R
Tektro Orion 4 pot Brakes & Superstar 203mm rotors
Shimano Zee cranks
Shimano Saint 10 speed shifter & mech
Sam Hill 40mm direct mount stem
Syncros 800mm bars (will be cut down)
DMR camo Death Grips
HT components pedals - OD green
Gusset R Series camo saddle
Started building it today, but haven't finished as I got too hot & bothered trying to get the tyres on lol
Will post up some pictures later.
Posted : 23/06/2024 11:42 pm
leegee reacted
Screenshot_20240624-085304Screenshot_20240624-085325~2Screenshot_20240624-085338Screenshot_20240624-085405Screenshot_20240624-085423Screenshot_20240624-085442Screenshot_20240624-085458Screenshot_20240624-085513Screenshot_20240624-085529
Posted : 24/06/2024 10:01 am
leegee, joebristol, stbennett and 12 people reacted
Looks good. Can't wait to build stuff like this for junior but he's still on a balance bike.
Posted : 24/06/2024 10:07 am
anorak and anorak reacted
Awesome job 🙂   The journey begins now 🙂
Posted : 24/06/2024 10:21 am
dirkpitt74, joebristol, joebristol and 1 people reacted
Looking good 👍
Posted : 24/06/2024 10:49 am
OMG how hard are Continental Kryptotal-b'stard tyres to get on?
Ended up knackering the rim tape on one wheel getting it on - was even harder to get back off!!
A couple of snapped tyres levers and a thumb trapped between bead and rim made for an interesting hour last night lol
Just brakes to bleed and shock to re-fit now.
Posted : 30/06/2024 12:47 am
Those brake levers are way too close to the grips, don't forget to adjust them for small hands as the reach is also massive on them. I see so many kids riding with badly setup brake levers. For a 'small' person you probably want to cut the bars down a bit as well.
Posted : 30/06/2024 7:55 am
Thanks for the comments.
Will sort final lever position once I've bled them and cut bars down.
They're actually more onboard now as I swapped the shifter to the grip side.
Posted : 30/06/2024 10:59 am
OMG how hard are Continental Kryptotal-b’stard tyres to get on?
On days like yesterday , leave them in the sun for an hour. I leave on top of the van so it gets both sides pretty hot and softens them up nicely.
Posted : 30/06/2024 1:12 pm
It's finished!!
Well it was finished a couple of weeks back as Daughter wanted it for our holiday to Scotland.
D
Her first ride on it was the skills area at Nevis Range, and then the World Cup track!
Missed out a few of the gnarlier sections and gap jump.
She seems quite at home on the bike, so we also got her a 1/2 day's coaching at Nevis a couple of days later.
By the end of it the only thing she didn't have a go at was the river gap.
The coach was well impressed with her.
Not fast runs but all very clean.
So tomorrow is first race on the DH bike - local race at Stile Cop.
We've been up a few times the last week or so, so she has a good grasp of the course.
We're off to Dyfi in a couple of weeks and then the MIJ races.
All in it's cost just shy of £800, which I think is pretty impressive.
**Pictures not working ? ***
Posted : 03/08/2024 10:33 pm
geeh, weeksy, ads678 and 9 people reacted
[URL= https://thumbsnap.com/t/d5i1BgZq.jp g" target="_blank">https://thumbsnap.com/t/d5i1BgZq.jp g"/> [/IMG][/URL]
[URL= https://thumbsnap.com/t/FX5RFqz5.jp g" target="_blank">https://thumbsnap.com/t/FX5RFqz5.jp g"/> [/IMG][/URL]
[URL= https://thumbsnap.com/t/zg6SMpez.jp g" target="_blank">https://thumbsnap.com/t/zg6SMpez.jp g"/> [/IMG][/URL]
[URL= https://thumbsnap.com/t/Bc58jcig.jp g" target="_blank">https://thumbsnap.com/t/Bc58jcig.jp g"/> [/IMG][/URL]
[URL= https://thumbsnap.com/t/PGRZnaTH.jp g" target="_blank">https://thumbsnap.com/t/PGRZnaTH.jp g"/> [/IMG][/URL]
[URL= https://thumbsnap.com/t/wWE9HTaq.jp g" target="_blank">https://thumbsnap.com/t/wWE9HTaq.jp g"/> [/IMG][/URL]
Posted : 03/08/2024 11:28 pm
joebristol, weeksy, weeksy and 1 people reacted
Fort William World Cup DH track:
[URL= https://thumbsnap.com/t/C9HRXPZg.jp g" target="_blank">https://thumbsnap.com/t/C9HRXPZg.jp g"/> [/IMG][/URL]
[URL= https://thumbsnap.com/t/qF4VR7Eb.jp g" target="_blank">https://thumbsnap.com/t/qF4VR7Eb.jp g"/> [/IMG][/URL]
Click to play:
[URL= https://thumbsnap.com/t/bu7AgNFS.jp g" target="_blank">https://thumbsnap.com/t/bu7AgNFS.jp g"/> [/IMG][/URL]
Coach Antoine:
[URL= https://thumbsnap.com/t/FDvxnkK3.jp g" target="_blank">https://thumbsnap.com/t/FDvxnkK3.jp g"/> [/IMG][/URL]
Stile Cop practice (click to play):
Free Photo Sharing by ThumbSnap
Posted : 03/08/2024 11:39 pm
dc1988, joebristol, weeksy and 7 people reacted
Picked up an 'upgrade' yesterday at the local DH race.
Suntour Voro coil shock courtesy of WC racer Dan Slack (Currently on Pole Racing).
I'll need to fix yesterday race damage first though before we start on the upgrades lol
Posted : 05/08/2024 4:41 pm
So we haven't done much to the current bike other than maintenance and messing with fork & shock settings to get a better ride.
It's still riding well and going strong.
It is getting a bit small though.... the joy of kids growing lol
So we decided that by the start of next race season it'll be too small and we'd need something bigger.
I'd enquired about a couple of frames on Pinkbike & a couple of other site but was being messed around so decided to avoid (especially after being scammed over some wheels).
Stile Cop race last Sunday had a few people selling stuff and came across a 2022 Vitus Dominer frame with shock and forks for a not too bad price. I kept looking at it throughout the day and must have bored the seller with umpteen questions.
Well at the end of the racing I decided to see if I could strike a deal.
After a bit of haggling we came to an arrangement, and we now have next seasons bike sorted:
Super clean, invisiframed from new and any stone chips have been touched up.
I've ordered a 275lb spring for the shock, so hopefully that'll arrive fairly soon.
Plan is to swap most of the parts off the current set up and sell that as frame, forks & wheels.
She's going to do the last 2 races on the Commencal and then we'll strip it down and build up the Vitus.
Posted : 23/09/2025 1:46 pm
tomdubz reacted
Looks nicely looked after. You going to check/service all the bearings before racing it?
Posted : 23/09/2025 1:49 pm
dirkpitt74 reacted
Yeah will give it a good looking over and check bearings.
Will get some spares too.
Posted : 23/09/2025 2:02 pm
weeksy reacted
Looks tidy that. How has she been getting on, presumably still enjoying it?
Posted : 23/09/2025 8:00 pm
dirkpitt74 reacted
Posted by: superstu
Thanks.
She's still enjoying it - more time on the DH bike is paying off. Even if it is just on the local 90 second DH runs.
The extra coaching with Katy is paying off, and the coaching she's had at Nevis the last couple of times we've been has been a big boost - more comfortable on steep and rocky and nailed the river gap too
Definitely getting faster and more confident - but the technique is improving too.
https://singletrackworld.com/forum/bike-forum/well-thats-racing-daughters-foray-into-down-hill/
Posted : 23/09/2025 9:13 pm
Vitus made decent bikes. The escarpe and the more enduro one I forgot about looked like skinny versions of this. Quite simple (in a good way) so should be easy enough to keep running through a season or two 👍
Posted : 23/09/2025 9:24 pm
Posted by: suspendedanimation
Agree - they made some decent bikes.
Funnily enough I built her a Sommet (160 Enduro sled) earlier in the year to replace the Escarpe she'd outgrown.
Posted : 23/09/2025 9:43 pm
weeksy reacted
The alu Sommet and Escarpe share the same front triangle. That Dominer front triangle looks suspiciously similar/the same as well!
Those Sommet black on black frames were warranty frames (before the closing down sale) dished out to those who snapped the rear ends of Escarpes (fairly common). A lad I know got one that way! The Sommets have a heavy/stronger rear triangle and don't seem to be as prone to snapping as the Escarpe.
Posted : 24/09/2025 2:04 am
dirkpitt74 reacted
So the new build it (almost...) finished.
Cleaned after first shakedown run at the local DH trails - it was muddy....
Saint cranks & Crank Bros Stamp pedals
Zee 10 speed rear mech and 11-25 cassette
Zee brakes and XT 10 speed shifter
Tag metals bars and DMR Deathgrips
It's currently running the old wheels off the Commencal build as I ordered the wrong size rear tyre - ordered a 2.6 instead of 2.4 and it's a bit tight on clearance.....
So waiting for another Kryptotal Rear to drop through the door.
Shiny new set of Halo Chaos wheels waiting to go on once the new rear turns up.
It had a bit of work done before the build by Ronan Dunne's race mechanic:
Frame pivot bearings all changed and the Boxxer has had the damper upgraded to the Charger 2.1 RC2 and lighter 275lb spring.
First race outing is in a couple of weeks at Stile Cop.
So far she seems happy with it and it's a big upgrade over the previous Commencal, longer and slacker so more stable and lighter too.
Not weighed it yet but I guess at least 1 - 1.5kg lighter.
I had looked at carrying parts over to the new build, but for the extra cost it was worth going with the new stuff.
Posted : 09/02/2026 4:52 pm
weeksy and citizenlee reacted
Here we go, final build ready for the weekends race:
Posted : 20/02/2026 12:40 pm
muggomagic, gringo, jfab and 2 people reacted
Nice! Got to love a DH bike, usually overkill for most of what I ride, but there's something so great about having a bike you can just smash through anything on!
Posted : 20/02/2026 8:25 pm
Looks awesome, I'd love a DH bike but they're fairly rare so never seem to be available at a price I can afford!
Is the B tension set correctly, just seems as though the jockey wheels are a long way from the cassette.
Posted : 22/02/2026 12:15 am
That’s a pretty looking bike. Just the right amount of red on it, not overdone. Hope she did ok at her race!
Posted : 22/02/2026 9:02 pm
Posted by: dc1988
Correct, It wasn't - I sorted it before the race though.
Posted : 06/03/2026 7:50 pm
