Narrowest tyres/hig...
[Closed] Narrowest tyres/highest pressure on Hope Tech XC's?
I'm wondering if I can set up a set of Hope Tech XC wheels with 32mm tyres
It'd be tubeless, with I guess 75 psi if I was mostly heading out on the roads, lower if on easy bridleways
They're lighter than my current road rims (Mavic Open Pro's) and wider, so I like the idea...
What could/will go wrong?
Posted : 03/07/2018 9:44 pm
You'd be exposing the rims?
Posted : 03/07/2018 9:53 pm
Exposing to what?
Posted : 03/07/2018 10:46 pm
You'll be fine, crack on.
Posted : 03/07/2018 11:25 pm
 PJay
When I contacted Hope about the max. pressure on my XC wheels I was quoted 60psi regardless of whether they were tubeless or tubed.
In terms of width, I was quoted 1.5" (38) to 2.3".
Posted : 04/07/2018 8:42 am
I tried doing the same on those Hope Tech XC rims. I ran Schwalbe G-Ones at 50psi. The rear kept loosing tension frequently. Local wheel builder advised the spokes Hope used could not cope with the higher tubeless pressures.
I ended up having the wheel rebuilt in the end.
Posted : 04/07/2018 8:46 am
When I posted about this previously, a few on here were adamant that this can't happen.
IME there's little benefit in inflating the likes of a tubeless 40mm G-One beyond 50psi - worth experimenting.
Posted : 04/07/2018 9:47 am
It was the rear 35mm going to 50psi for road rides. I have a 40mm on the front which never went beyond 40psi. I never experienced the same issue with the front.
it just seemed to be the narrower tyre at the slightly higher pressure causing the issues.
Posted : 04/07/2018 11:13 am
