n00b time - Cassett...
[Closed] n00b time - Cassettes
Latest in my series of mildly idiotic threads comes a question about cassettes.
I have an old rear wheel which has a 9 speed cassette on that I use on the turbo trainer (using a mountain bike). However, the cassette is quite worn so I'm looking to change it.
Would I be OK using this - http://www.chainreactioncycles.com/Models.aspx?ModelID=69266
It's in the MTB Cassette section, so I assume it's OK, just with it being 'Sora' want to double check.
Also, might as well tag this on - Would I be OK using a SRAM cassette with an XT mech/derailleur?
Thanks in advance for your patience and your time ๐Ÿ˜€
Posted : 15/02/2012 9:48 pm
Yes and yes. 'Sora' (as opposed to SLX, XT etc etc) just means it'll be heavier, perhaps more durable, and less 'bling'.
And yes, you can use SRAM drivetrain parts (cassette, chain) with Shimano gears and vice versa. You generally can't mix Shimano and SRAM gears and levers, but cassettes, chains, chainsets should be fine.
Posted : 15/02/2012 10:13 pm
you can use whatever brand casette so long as your chain will fit on it i.e. 9sp chain for 9sp cassette. not sure about using a road cassette for mtb though I suspect it wouldn't matter?
Posted : 15/02/2012 10:14 pm
Cheers people. Just for the turbo wheel, so I'll purchase. Thanks.
Posted : 15/02/2012 10:29 pm
aye what they said i use a mtb one on my road bike [seperate wheel] for turbo duties as it was all I had spare
Posted : 15/02/2012 10:40 pm
I'd get a cassette with the same ratios or you might run into problems with the cassette hitting the large rings.
or just make sure you only use the smaller sprockets.
Posted : 15/02/2012 11:15 pm
