Mullet e-bike Wheel...
Mullet e-bike Wheels?
[#13535592]
I'm looking for a set of wheels to go on a Trek Rail to replace the OEM Bontrager wheels.
What's a decent wheelset with a budget up to around £500 max?
Posted : 18/05/2026 11:12 am
Topic Tags
Hope do the Fortus 30/Pro 5e rear in 27.5. Paired with the 29" front you'd be looking at around £470.
There's the DT Swiss HX1700 wheelset too, and Mavic also offer the E-Deemax as a 29/27.5 wheelset. Not sure if either are any good, but both are under £500.
I'm sure Hunt will have something.
Posted : 18/05/2026 11:27 am
 a11y
DT 370 hubs, 1960g and lifetime warranty on the rims for <£500: https://www.merlincycles.com/reserve-30sl-al-6069-mx-wheelset-29-275-342062.html
Might be better with the 30 HD rim but I've not seen those at similar price. But lifetime warranty...
Posted : 18/05/2026 12:03 pm
Posted by: a11y
Interesting. I was just looking at Reserve wheels and as you say, they seem to recommend the 30 HD for e-bike use. Not really sure what the difference is but I'll take a look.
Reserve have the 30 HD with the DT350 hub and the older 90t freehub rather then the fancy Degree of Freedom ones for £519 which seems a good deal.
https://uk.reservewheels.com/products/reserve-30-hd-al?variant=56490842292601
Posted : 18/05/2026 12:31 pm
Posted by: citizenlee
I have this set up on my 28kg 180mm Kenevo and it's been bombproof
Posted : 18/05/2026 12:34 pm
 a11y
Fairly sure the MX set of those is out of stock at Reserve when you select the correct options - not that I've been looking...
It's a shame they don't keep the same price as the 27.5 set when you select mullet option on these. They do have mullet set with i9 Hydra hubs for £880 but that's way over your budget and I believe Hydra axles can be a bit snappy. I'm happy with the cheaper i9 1/1 hubs I have though.
Posted : 18/05/2026 12:41 pm
You're correct, they're out of stock. I must have misread the page when I was browsing.
Posted : 18/05/2026 1:05 pm
2 sets of Mavic E-DeeMax here, also faultless. Tubeless is beyond easy, ratchet hubs and the rims seem to be made from undentium... Great wheels IMHO.
Posted : 18/05/2026 1:16 pm
https://www.bird.bike/product/factory-wheels-boost-dt-swiss-350-hub-ms-dt-ex511-mx-30-off/
These are pretty keenly priced
Posted : 18/05/2026 1:35 pm
Can recommend this (online) place  - https://www.bikewheelsdirect.com/    Russell Crowe (not that one), gives great advice on wheels. Can build to your spec. My son (not an ebiker) but a regular smasher of wheels had a set of DT FR541 on Hope built, we checked them for the first time since he bought them months ago and only 2 spokes had come slightly loose
I got a HX531 on Hope from them.
Posted : 18/05/2026 2:05 pm
