Mudguards with drop...
[Closed] Mudguards with dropper posts ?
I know, I know, I need to MTFU ......
But, what mudguards are people using with dropper seatposts these days ?
Usually use Crud Guards in the winter, but obviously not such a great idea with a dropper.
Or are they ?
TIA
Posted : 24/05/2014 7:59 am
Mudhugger would work as it mounts to the frame not the seatpost?
https://www.themudhugger.co.uk/shop/
Si
Posted : 24/05/2014 8:03 am
I had just enough of the lower part of the dropper protruding to attach a crud catcher thing.
I don't think its a case of mtfu, just makes sense to me not to unnessicarily cover myself in crap, especially on a longer day out.
Posted : 24/05/2014 8:15 am
I've got the crud guard mounted on the frame - I threw the rubber shim away and used a bit of inner tube, and it just goes on the 'stub' of seat tube. I'd rather not cover myself, or the dropper.
Posted : 24/05/2014 9:04 am
Another mudhugger user here, goes on the top of some amalgamating tape and i cut and reapply the cable ties when the weather gets shitty again.
Posted : 24/05/2014 9:26 am
I use a decathlon thing that should attach to canti studs but works just as well with p-clips. I'd say a guard was even more important with an expensive dropper post in the firing line.
Posted : 24/05/2014 10:26 am
I've since dumped the rubber bands and drilled a couple of holes in the front guard so I can bolt it into the cable guide bosses.
Posted : 24/05/2014 11:21 am
That's a 29er but also available for kiddy wheels: http://www.wiggle.co.uk/zefal-no-mud-26-front-or-rear-clip-on-mudguard/
Posted : 24/05/2014 5:41 pm
mudhugger ftw:
I drop the dropper into the frame so a seatpost mounted mudguard is a no for me
With the seattube being so low down, the 29er version would work better on that bike though, a few splashes do get past, but nothing to get your shorts wet
Posted : 24/05/2014 6:14 pm
Another mudhugger user here, really pleased with it, backside completely dry on Thursday night after a muddy ride, didn't have to put a seat cover in the car either.
Posted : 24/05/2014 7:43 pm
I've got a Zefal No-Mud and my mate has a mud hugger. Pro's and cons. The Mudhugger is definately more effective due to the way it straightens out at its end, but the Zefal can be removed and installed more daily - though last winter I couldn't be bothered and left it on. However in both cases they wore through the paint and into the metal of the chainstay's so in both cases make sure you use plenty of thick hell-tape to protect the frame.
Posted : 24/05/2014 8:05 pm
What you all need is a direct mount mudhugger.
Stainless fittings mean no paint to wear off, no corrosion issues and makes taking them off or on pretty easy.
not using all those, btw.
[url= http://revanchebikeco.wordpress.com/2014/05/19/hardtails-winter-and-the-mudhugger/ ]read all about it.[/url]
Posted : 25/05/2014 6:35 pm
There are some slightly cheaper ways to add "aesthetic challenge" to your life...
Orsumz!
Posted : 25/05/2014 6:53 pm
well, the romans conquered most of yurp with sandals and socks...
surprisingly comfortable, tbh.
Posted : 25/05/2014 7:17 pm
Well, being a shortarse and having decided to try a dropper post, I was quite sure that with the post installed and pushed right down (as it has to be given my stature) I would have to bin my Topeak Defender. But no. It fits successfully around the seat tube below the clamp.
Posted : 25/05/2014 7:32 pm
mudhugger here too, no seatpost issues whatsoever
Posted : 25/05/2014 9:09 pm
