Mudguards for a Nor...
[Closed] Mudguards for a Norco Threshold A2
I will be needing some mudguards for my threshold, has anyone fitted any to one of these bikes? The rear has a flip chip (apparently) to mount the guards so rear shouldn't be too much of an issue. The front only has a mount point at the crown of the forks, there is nothing near the axle.
Are there specific guards for this sort of application or do i need to get some P-clips and mount onto these?
Thanks
Posted : 13/11/2015 12:10 pm
I have fitted guards to my norco threshold A3. If I recall there are mounting points at the bottom of the fork on my (mine doesn't have the bolt through axle of the higher spec ones) Assuming yours has the same fork it should be. Did require some bending of the mudguard stays to clear the disk but wasn't too much of a pain to fit. SKS longboards for me which are amazing!
Posted : 13/11/2015 12:20 pm
Mine has the bolt through axle carbon fork fitted to it so no mounts at the bottom. It has got discs, hadn't thought about the stays clearing the disc and caliper, good point. Something else to ponder over.
Posted : 13/11/2015 12:38 pm
