I have just fitted a reverb seat post and my mud gaurd will no longer fit on the seat post, there is no way I can fasten it to the down tube as it will hit the wheel when the suspension compresses, I could really do with somthing that fastens on the little wish bone if you know what i mean, I really dont like riding with out a mud gaurd, It does spoil the look of the bike, but makes it so much more comfortable if your out for a while and not having to put up with a wet back side
does ony one do any thing like im looking for
thanks
What about an ass saver - or cut a mudguard shaped thingy out of a milk bottle which fastens under the seat
Edit - mtfu ๐
ass saver ?
I had same problem wenr for mucky nuts butt defender, dosent do the job of a full mudgaurd but it helps
A bit 'sad' looking, but the Zefals seem to have solved the problem - I'd plump for those on the grounds that you only chew on doggy doo once in you life ๐ฏ
There have been two threads on here about solutions. Search for them and you will see some suggestions. I mounted a crud catcher using the bracket upside down to get it to fit.
