So you think an entire bike cover is in order then
Only braking surfaces. I don’t personally care if my bike looks “dirty”, but don’t want contaminated discs and pads (again).
Though why not just tie a plastic carrier bag around them. whats the cost of a reuseable carrier bag ?
This is what I used to do. Flappy flappy. The Hope thingies work so much better, and double up as a protector between two bikes. Obviously there are free/cheap alternatives… use them if you want, but these work nicely and cost very little really.
As for the “short drive to the trial centre” comment… that’s valid. But personally I only put bikes on the back of the car when going travelling with a full load and family a long distance for a week or more away. Long motorway journeys are where disks get messed up. A clean and a wipe are all they normally need if not covering them. But, belt and braces on long trips, to avoid having shite brakes… well, why not?
I guess the why not for me is the lack of a need for this...despite 500mile trips with bikes on back and in some very changeable weather conditions...I've obviously been lucky as never had an issue with brakes, so I've never needed to consider covering them.
This seems to be a seed being planted in minds and then people thinking it is needed, but suspect it is a non-existant issue for most people...
Not to say it doesn't happen but I've never met anyone in real life with this issue, plenty folk online buying them to prevent this but very few experienced it. So I suspect the reality of this is very small and works by people suddenly thinking it might be an issue.
Appreciate this is a polar opposite thought to how this thread started, sorry.
To get back to the OP’s question
Muc-off disc brake covers? are they worth it or is it just good marketing?
If you are not currently bodging something and think these are a good solution or took one look at them and thought they solved a problem for you then you would probably be wasting your money. For me, I’m one of those obviously rare people whose discs get covered in crap on the tow bar rack (mostly if wet) leading to the first part of a ride being with graunchy and/or noisy brakes. I’d have bought some of these ages ago if I hadn’t thought they wouldn’t survive the car trip. I won’t use them for maintenance
I bought these after years of crap post drive brake performance, followed by years of flappy plastic bags and spray/wipe clean before first ride. They’re cheap, they work, they save me hassle. No one else has to buy them. I don’t think I’ve ever even recommended them to anyone ‘till I read this thread where people were asking if they are a rip off or pointless. They are neither in my book, but no one has to buy them. I’d very surprised if anyone bought them simply because they “thought they needed them”, unless they had contaminated their discs before… either driving or cleaning/lubing. Why would you? Not had a problem before, don’t even consider them. Personally, I’ve had plenty of rides ruined in the past by disc/pad contamination, and don’t any more. Job done.
Disc brake cleaner is a better first purchase though (cycle specific not car/motorcycle formulae, of course).
Alternatively you could use a shower cap, at about £1.99. £18 cheaper.
A few people have suggested shower caps. Personally, I don't think I'd want to use something that'll end up at a landfill every time I clean my bike.
But I agree the price is ridiculous though.
This is me.
Yes, I suffer from post-drive brake contamination.
Yes, I've faffed with plastic bags, insulating tape and clingfilm.
Yes, I've arrived to find it has blown off somewhere en route, adding to roadside littering.
No, I've never mentioned it on here trying to implant an idea in someone's head.
No, I don't have shares in Muc Off.
No, I didn't invent them and so do not get some sort of royalty payment.
FWIW I got them quite a bit cheaper than RRP so I actually bought two pairs.
Mine just arrived, no more manky brakes for me 😀
I have a set, don't use them that often, but super useful when I do.
But when I have just rinsed all the crud off my bike and am short on time, they are great to whack over my rear disk and give the cassette & chain a squirt of something to deal with the moisture. Lazy? Yes. Better than doing nothing? Also yes.
Are there cheaper/more free options? Yes.
Are those cheaper/free options as free from faffage? No.
Are there better options? It depends....
For my use case, I initially bodged up some plastic that just protected the disc from cassette overspray. Turns out that THIS THINGY is a commercial product that does the same (although arguably slicker). Muc Off things were a grumpy purchase after the third time on a windy afternoon where my bodge got whipped away by the wind while spraying. They have a couple of flaws (like the fact I expect them to crack at some point) but they sure don't blow away.
Do I begrudge a company finding a solution to a problem that some would say does not exist? No. The problem clearly does exist but we've all been bodging our way around it for years.
This is what I was getting at with my original post. If I clean my bike in winter and put it in the garage I don't want it rusting from trapped water so I clear the water with bike protect. I'd rather be safe than sorry 👍
As for the brake shield thingy, the description said it only goes up to 40t rear cassettes or something so I ruled it out.
Tried this ages ago for when I used to scrub my cassette didnt work too well, also moved onto Peatys foaming degreaser which needs next to no scrubbing.
I have a towbar bike rack and found this winter the brake contamination to be awful, my brakes would either howl like a banshee or not work, I got around this by a quick rinse before I rode using my portable washer, since the weather got better this hasnt been an issue for me, until yesterday when I got to the local steep tech spot and had no rear brake, scrubbing the pads and disc in mud didnt work so had to abort the ride early. Got home very annoyed and have ordered the muc off disc covers, £20 to avoid rides getting cut short after a long drive is well worth it in my opinion, shame about the colour options though.
Hint: if the bike is mounted with the rotors facing the car/van, no one will notice.
OTOH the bright design is an extra visual reminder for folk behind you (yes, I've had someone drive into the back of me at a roundabout while the rack was fitted)
Do they do a range of colours, I need to match to my A4?
No, the easy option is to have you A4 wrapped Grey and Bright Pink to match the covers
Disc covers have arrived and been used, I think the colour is worse in real life though!
They just about fit around my 220mm rotors but they kept anything getting onto my rotors and contaminating it for a few uses now.
I’ve always been a stickler for not letting anything near my discs or pads, even to the point of not touching the pad material with my fingers, then a week ago, I got my bike out the car in Wharncliffe car park at the start of a week away, put the wheels in, and rode around the car park, the front brake (Hope V4) was howling and not working, I’d recently rebuilt it with new seals and pistons, and it had been perfect the ride before, I got off looked and found the disc dripping in oil! (Turned out to be vacuum pump oil which had leaked out a bottle in the car) a friend had just turned up to ride with me, it was Sunday afternoon, So I wiped the disc with baby wipes, held the pads with a leatherman and used a Clipper lighter on them until they stopped smoking, then rubbed them around on the ground a bit. They squealed for a couple of hours, but worked surprisingly well and I did 38,500 feet of descending in the following 7 days and they were fine.
