Moving to a 1x9 set...
[Closed] Moving to a 1x9 set up
This is prob a daft question but can I just use my XT cranks and drop the big and granny rings or would it be better to get a single ring crank? only ever used single ring cranks on DH bikes not on XC.. would prefer to use my existing cranks, if thats fine will an LG1 fit over considering it will have the tabs for the other 2 rings? cheers
Posted : 04/02/2010 1:06 pm
Posted : 04/02/2010 1:08 pm
You can use your xt cranks but you'll need 4 spring loaded washers (easiest option) or new bolts to keep the chainring on.
Posted : 04/02/2010 1:11 pm
ohhh good point forgot that I would need shorter bolts
Posted : 04/02/2010 1:15 pm
Shorter bolts are cheaper than new cranks....
Posted : 04/02/2010 1:21 pm
Or washers. If you buy an MRP chainguide they give you some washers. Bit uglier than short bolts, but if you want I could probably post my spare ones to you. Otherwise hubjub do cheap short bolts.
Posted : 04/02/2010 1:24 pm
lg1 wii work fine with your cranks, none of the tabs stick out far enough to interfere. and wot they said about bolts
Posted : 04/02/2010 1:26 pm
FWIW i'm using old LX cranks and they're fine.
Posted : 04/02/2010 1:28 pm
LG1 and XT cranks fit together perfectly:
No adjustment/modification required. Short bolts came with LG1.
Posted : 04/02/2010 1:32 pm
thanks all, does anyone know of anywhere that sell the short Chainring bolts cheapish? either that or in Ti to last a lifetime?.
Posted : 04/02/2010 1:33 pm
I got short chainring bolts off charlie the bike monger - IIRC the price was fine
Posted : 04/02/2010 1:40 pm
Here for £5:
http://www.hubjub.co.uk/etc/etc.htm
Posted : 04/02/2010 1:41 pm
loads of short bolts on ebay for around 5-6 quid. I needed some long ones and just sold my short stainless ones. Could have swapped you too.
Posted : 04/02/2010 2:05 pm
here for £4.99 and we also have the MRP chain guides for 1x9.
http://www.charliethebikemonger.com/userimages/procart4.htm
Posted : 04/02/2010 2:09 pm
MMmmmmmmm
Posted : 09/02/2010 9:57 am
