motion control to b...
[Closed] motion control to black box conversion
Who has done this?
Can it be done DIY or is it a send away job, who to and cost?
Posted : 11/01/2012 12:33 pm
DIY. Unscrew top cap. Remove damper. Put new damper in. Tighten top cap. 5 minutes.
Not changed, but removed MoCo from my Reba WCs and Black Box MoCo from my SIDs, and the process was identical!
Posted : 11/01/2012 1:28 pm
I did it to my reba 29 RL, swapped over the rebound damper too so took around 30 minutes as you need to drop the lowers. Already had the parts but I believe TFTuned do BB kits.
Posted : 11/01/2012 1:41 pm
It's easy to do. If you've done the 'normal' fork service, and can read instructions, you won't have a problem. You need some specific tools though, depending on the exact fork model. Circlip pliers and a 32mm (?) socket.
Posted : 11/01/2012 1:48 pm
 nuke
[i] a 32mm (?) socket.[/i]
24mm
Try Loco for the RS bits you need.
Posted : 11/01/2012 1:52 pm
