Got a set of revelations 2012-ish.
Locked out on the dial is fully open, and fully open is locked out.
Anyone seen this before and got a DIY solution?
Posted : 04/08/2015 8:42 pm
Are they new to you?
Last new Revs I bought came with a bar mounted lock out. I swapped it for a crown lock out but I have the same problem as you, lock out and open don't correspond with the graphics on the lever.
Posted : 04/08/2015 8:54 pm
No, had them a while. This behaviour is new though.
Posted : 04/08/2015 8:55 pm
What Damper? Is the tab in the same position as before?
Posted : 04/08/2015 9:04 pm
Sounds like the half moon at the bottom of the damper has moved - I just used pliers to move it back into place on my old Revs and Pikes.
Posted : 04/08/2015 9:26 pm
Finally got around to poking around at these to have a look.
Disc at the bottom of the damper was rotated, bit like teethgrinder said...
Posted : 31/08/2015 8:47 pm
