Morzine - Singletra...
[Closed] Morzine - Singletrack - Route Choices
[i]Previous post had incorrect title hence the re-post [/i]
HI all,
I'm in Morzine (again) for a week this summer and have in mind to ride some of the usual single track routes. Based on articles in this forum I've found a few but had some questions on them with regard to the best options:-
1, Col De Cou / Arrete Berois - I've ridden this before.
2 questions - is it worth riding / walking up to the actual col or should I skip the last part of the climb (which i did last time) and traverse over just before the top.
Also, at the end of the ridge after the steep switchbacks where you hit the car park. Last time i went right down towards Barme then took the fireroad under the Cliffs. I see at the car park that you could go left instead crossing over one road then presumably taking the next one into Champery. Is this route any better than the Barme route?
2. Samoens descent / Le Bourgoise
These seems to be mentioned a lot but I am a little puzzled, unless i'm mistaken whilst you can descend on the ridge until the road, crossing over the hairpins there appear to be a few options which eventually land you in Cessonex, it then looks like a bit of road trip across to Chantemerle before the last off road section into Samoens. The other alternative i have seen is descending off the main ridge (Bourgoise pt1 on strava) and ending up in La rosiere and then road it down to Chantemerle for the last off-road section. The latter seems to give more off-road riding but I don't see it referred to as much.
3.Col De La Basse to Essert Romand
The map I have shows 2 routes. Descending North East from the col, through Les Prez, you hit Sur Lachaud. At Sur Lachaud is it better to go North to Le Plan de Criou or continue East along the ridge and then descend NW to hit the path between Le Plan de Criou and Essert Romand
4 La Morzinette.I recall seeing a short video of this descent from Avoriaz. On the map it looks like a short climb out of Avoriaz followed by a traverse and descent to Morzinette. There appears to be fair degree of climbing in places before the descent. Has anyone ridden this route. Would be interesting in your views.
Obviously if anyone has other suggestions they would be much appreciated.
Thanks
Carl
Posted : 26/06/2017 9:52 am
1. not done it myself yet
2. route goes on down the ridge past Sur les Chables, briefly on road at la Chemossaz again, then off road below the road to Cessonex.
3. Descent from C de la Basse as far as Les Paquis, then double track climb towards Sur Lachaud.
Dont go north to Le Plan de Criou, instead continue along ridge and descent to the next left marked on the IGN (under the N of les Bois Noirs)
4. Ive walked to Morzinette from Avoriaz (as part of a loop taking in Les Hauts Forts 2466m). Im not sure which route the video takes, but Id not want to take a bike on the route I took via La Chaux. The lower route via les cótes may be more appropriate.
Posted : 26/06/2017 10:03 am
Thanks Stoner.
Would still be interested if anyone has ridden the other descent to Samoens. as per your kindly posted map there appears to be a route down the face of the bourgeoise which ends in mouchallaz. I thought I saw a vid of this route posted in one of the Samoens threads
Thanks
Posted : 26/06/2017 11:46 pm
I would hazard that that is a really steep section off the ridge.
Nothing showing on strava heatmap or http://www.vttrack.fr/ for anyone having recorded it.
You never know, you could be the pathfinder! Do video it though, wont you?! 😉
Posted : 26/06/2017 11:51 pm
Sorry to hijack the thread slightly, but I'm heading out to Samoens in August for a week, and I've seen some plans [url= http://s.info.grand-massif.com/5654/www/Carte-VTT-2017-avec-zones-fermees.pdf ]online[/url] that show quite a few trails are closed from the top of the Samoens 1600 lift and above this summer? Anyone have any idea what extent is closed and whether the Chariande Express lift is running this summer for bikes?
I was planning on trying a loop from Samoens using the lifts over to Flaine and then from the top of the Grandes Platieres down into Sixt. Anyone done a similar route at all?
Dave
Posted : 27/06/2017 3:49 pm
 leth
Does anyone know of a good taxi service from Samoens back to the top of Les Gets bike park?
Fancy doing Le Bourgoise, but dont fancy the ride back up>
Posted : 27/06/2017 6:30 pm
1. We didn't push up as we where knackered 😳 I would say its worth it for the view and to know you've done the very top, its a singletrack straight roll down as far as I recall. Note at end of Arete (roughly 1619m point here) turn left to Planafranche for best final descent option imo. map to follow, upload taking ages 🙁
2. I have only done the route in Stoner's post (which I like very much). I found this website the other day and it shows the steeper option you mention off the top. The route I've done is a mix of these two
Taxi - we booked one via our Morzine hotel with a trailer (3 of us) and organised it for the end of the day (6pm) so we could ride descent after a full day and then have a beer in the nice Samoens town square.
Posted : 27/06/2017 6:57 pm
If anyone want to [s]guide[/s] show us round Samoens next week please get in touch.
Posted : 27/06/2017 7:37 pm
Col du Cou / Arete Berrois map (from excellent Swiss Mobility App)
Posted : 27/06/2017 7:54 pm
@warrend / godzilla if you contact Bike-Alp and ask nicely they may be able help you. They ran guided holidays in Samoens for years before moving to Brianacon last season.
Posted : 27/06/2017 7:58 pm
Warrend, I guess the closures are while construction is under way fro the Club Med?
For guiding, Jamie @Ride the Alps in Morillon.
Tom Ward-Lee who runs Alps Accommodation in Samoens may be around/able to assist otherwise.
Posted : 27/06/2017 8:16 pm
I've done the Samoens decent a few times now and the route we take goes pretty much straight into the town centre. I'm rubbish at remembering directions as I'm usually hanging on for dear life and not taking in where we are going! I do remember heading off the peak toward Samoens and heading left after 100m or so. The trail takes you under a bent tree (scar to prove) and then into switchbacks. It follows the road down pretty much and crosses a few open gardens at the bottom. As mentioned above, Steve from bike-alp maybe able to give you some directions but had moved away or Jamie from Ride the Alps is still local.
We had a few trials closed last year, but it's only the start of them. We spoke to the locals who gave us directions on how to join onto them. We rode all of them with no problems. This is due to Club Med building a hotel Just below the mid lift station. The Blue and red trails had a slight diversion and the top of Steepy Black and Chicken run were closed, but only the start.
From Flaine, you need to traverse over to the top of Morillon and ride the 3 black runs to the bottom to meet the road. It's about a 25min ride ride back to Samoens.
We're heading out on the 15th for hopefully another awesome week. This will be our 6 year and still not bored!!
Posted : 27/06/2017 8:41 pm
Watching this thread with interest.
Arete du Berroi is Ok, but I've only ridden the ridge as far as the col at 1816m and then down the farm track. Down from there is absolutely beautiful but not even slightly technical. However, going up the Col de Cou, after all that climbing I prefer the blast back into Morzine, sometimes via Les Mines D'Or and then on the Dranse track. Pure fast fun.
Stoner and Jambalaya speak the truth about La Bourgoise. I'm avoiding it in the wet this year.
Col De La Basse to Essert Romand is great fun. I haven't heard of the first variant you mention. The second is in the the VTopo guide but seems little used. It is rooty fun and frolics, steepening to a loose 4X4 access track down to Essert Romand. The wooded upper section from where you drop off the forest road into the trees is very reminiscent of the descent down from La Chapelle Janquicourt but steeper and longer.
There are details of the Morzinette descent in the vTopo guide too. I've never done it myself though.
Posted : 28/06/2017 12:08 am
Have done both Arete du Berroi and Col de Cou. Once to do the ridge, the other to drop over back in to Morzine. If I was doing the ridge, I'd probably skip the corner again.
For Essert Romand, I vaguely recall quite a bit of a fireroad ride but the descent thru the woods was ace.
Morzinet was a bit of a push. I'm not convinced we went the right way. Was a good run thru the trees though. I'll have to compare my GPS track if I still have it with the vtopo book.
Posted : 28/06/2017 1:06 am
Thanks for all the replies so far. They are much appreciated.
I have the vtopo guide English version but don't recall seeing the Morzinette route in there. Will double check this evening. I found another vid of the route last night and whilst some parts are clearly a push and there is likely to be much getting off the bike, some did look like fun.
Posted : 28/06/2017 1:58 pm
got a link to the vid?
If there was a lot of hikeabike, then it's quite possible its the higher route via La Chaux that I referred to. Still would rather walk it than ride it even though there's obviously some fun sections.
Posted : 28/06/2017 2:05 pm
jambalaya - what is the app name please? I cant find it
Posted : 28/06/2017 2:26 pm
alexxx - this is the webpage for swiss mapping.
you might find a link on here somewhere.
looking at jamba's screendump it looks like an Apple Stor app, so I cant help find it as Im android only.
https://map.schweizmobil.ch/?lang=en&bgLayer=pk&resolution=20&X=552016&Y=116544
EDIT: found it, link on the homepage of the mapping site: http://www.schweizmobil.ch/en/gratis-app-schweizmobil.html
Posted : 28/06/2017 2:33 pm
The website is here:
[url= http://www.mountainbikeland.ch/en/mountainbikeland.html ]MountainBikeLand[/url]
The app is called SwitzerlandMobility (on Android)
Posted : 28/06/2017 2:37 pm
Stoner ...this should work...
Also read some brief info on a singletrack called Pachorey Trail (looks like it goes down from Col De Joux Plane towards Morzine)
Posted : 28/06/2017 4:20 pm
Re Morzinette -
The original video I saw was on the Bike Magic Trail Guide website - entitled Autumn in Morzine. It does talk about a hike over boulders..
I'm afraid I'm unable to get the link to copy over and work
Posted : 28/06/2017 4:32 pm
Hopefully this works..
<p>Bike Magic Trail Guide TV - Reset Films - Alex & Loic Hidden Morzine a Mountain Biking video by resetfilms</p>
Posted : 28/06/2017 5:07 pm
just starting watching that youtube vid carlos, and yes it is the same route I have walked,
As you can see in the first 2 minutes upto where he goes under the ski lift TS des Grandes Combes, its pretty much unrideable for most of it.
Morzinette is visible at 4mins. Then the route hits the woods.
As second link says:
After considerable effort the ride proper begins, with flowing, fast open meadow sections that eventually enter the tiny hamlet before dropping into the forest for a loamy, technical and fast finish
very tough first section, but I can see the attraction of the later sections.
Posted : 28/06/2017 5:30 pm
@alex the others have it. FYi its quite useful to switch on suggested walking paths (green) I have found the vtt trails (yellow) generally more fireroad xc
Posted : 28/06/2017 5:34 pm
That's me in the youtube video. The route ridden is the one that goes via La Chaux and has a fair proportion of getting on and off the bike up until you go under the Grandes Combes lift. There's a very rocky and exposed switchback section almost immediately after you leave the piste above the Prodains lift, which isn't in the video. I played cautious and walked these as I was out on my own and no-one in my group knew where I was riding. Some of the following sections of singletrack feel like it starts to get going and then you'll encounter a really tight rock pinch or similar.
As to whether it's worth doing - the meadow singletrack and the stuff through the woods is fun once it gets going. I enjoyed it as a bit of exploration in a holiday which was mainly riding the bikepark and off piste DH trails (I had my downhill bike out there as well that year).
Posted : 28/06/2017 6:59 pm
 GEDA
This track down to Ardent was really nice except we got chased by one of those Polar bear like dogs.
[url= https://www.google.se/maps/place/46%C2%B01 3'21.7%22N+6%C2%B045'25.6%22E/@46.222685,6.7552785,17z/data=!3m1!4b1!4m5!3m4!1s0x0:0x0!8m2!3d46.222685!4d6.757119?hl=en]Ardent Descent[/url]
Posted : 28/06/2017 7:29 pm
tomtomr - gotta give you credit for doing the route on your tod, Quick question..at morzinette it looks like there are 2 route options either passing the hamlet on your right, and taking a right turn almost doubling back on yourself eventually ending up at les Ray...or you can pass the hamlet on your left and take what looks like a shallower descent to the left which eventually ends at Chalet de l'Acquy. Do you recall which one you did.
BTW -there is a route in Vtopo but this one sits below la chaux and doesn't make it to morzinette. Potentially more readable tho from what I've read
Posted : 28/06/2017 7:52 pm
Just watching that Morzinette vid. Looks familiar.
I vaguely recall riding up a ski piste and hanging a right on to a walking trail. Quite a bit of on/off bike carrying over rocks etc. for what seemed like a long way at the time, but might not be in reality. And then it's all flowy meadow. I just remember being in a bit that's not really rideable convinced we'd gone the wrong way, wondering if there's a 2nd path, but the map, my GPS, and the instructions given by Carl+Sian all tied up, and we could see where we were supposed to be getting to and realising that if you're half way thru, it's easier to keep going.
Ace day out though, off the beaten track (I think we saw a person).
At Morzinette, we went sort of left and kind of zigzagged down thru the trees. Not via Les Ray.
Posted : 28/06/2017 8:27 pm
As Andy says it's not down to Les Ray but the track that zigzags down via Chalet de l'Acquy. From memory after doing the steeper bit that goes straight down the fall line I then turned left and traversed round to Crepet.
It's very quiet out that way - I didn't see anyone after leaving the piste. The Prodains lift wasn't running that year though, so that might have contributed to the lack of walkers.
There's a small section on the video which isn't on the correct trail (around 50s to 1m19) where I took a wrong turn up the hill - that section is descending back down to the correct route.
Posted : 28/06/2017 9:04 pm
 leth
That Video Looks like a trail I've ridden. We came out here when we did the route.
[url= https://www.google.co.uk/maps/ @46.1835901,6.730116,3a,75y,187.33h,75.19t/data=!3m6!1e1!3m4!1sPqEqbs99jmcWXgLpjua8pg!2e0!7i13312!8i6656?hl=en][/url]
Posted : 28/06/2017 9:20 pm
Just as an fyi here is the col du cou / arete berrois map with walking routes on showing my preferred option ( on an stw mag route) of turning left at 1619 elevation. IME in Switzerland these green routes tend to be decent biking. eg many of best Verbier trails are marked this way
Posted : 29/06/2017 9:13 am
Do you have any suggestions for an app for offline French maps on Android?
Posted : 29/06/2017 9:47 am
I've not yet found one.
This works in browser if online though
http://www.walkingclub.org.uk/ign_france_maps/france.shtml
Posted : 29/06/2017 9:57 am
I use viewranger. Works really well for offline maps. You need to pay if you want proper ign maps though. Worth it imo and you only have to pay per tile so only a couple of quid for the whole PDS region. Easy to import and overlay gpx files too. Also compatible with android wear so you can ping a tiny map to your watch to save getting the phone out at junctions.
Posted : 29/06/2017 10:03 am
Magic bit of trail
Posted : 29/06/2017 2:02 pm
@Boarding a very happy 2 minutes spent watching that, brings back good memories 🙂 TBH the Arete itself I can take or leave as I spend most of it being worried about falling off one side or the other 😐
Viewranger is excellent. I didn't realise the IGN map tiles where so cheap - a couple of quid or is that a bit optimistic ? In the old days I just used to use browser access to the geoportal.gouv.fr site but detailed IGN maps have gone now.
Posted : 29/06/2017 4:23 pm
Thanks stoner I've got it thanks to your link but it's only switzerland how did it show france ?
Posted : 29/06/2017 7:35 pm
 leth
I may have managed to sort a lift from Samoens back to the top of Les Gets bike park.
How long roughly would the Le Borgeouise take?
Posted : 29/06/2017 8:35 pm
If anyone is up for doing the more technical route I'm here all season and haven't done it yet.
Can probably sort vehicles either end too.
Posted : 30/06/2017 9:38 am
@alexx SwitzerlandMobility app does not show France. The Col du Cou/Arete ride is mostly/all (?) in Switzerland
Yes I may be up for the steeper / more technical one in mid August
@leth its about a 1000m of descending but there is a ride in to the cross at La Bourgeoise with a bit of climbing and path is rutted by cows at start. Also on a clear day you'll spend a while staring at the view of Mont Blanc. 2hrs total should cover it inc a bit of time to check navigation
https://m.flickr.com/#/photos/sheldona/9278090046/in/set-72157634618088251/
Posted : 30/06/2017 9:46 am
Is it worth doing the Col De Cou descent towards Lac Des Mines d'Or rather than towards Champery?
I've considered it a few times but always end up doing the Swiss side. Much shorter day out if you drop back towards the Lac.
If it's worth it, what routes better. Looks there's a right or left option on the IGN map from the Col De Coux. Any one to avoid?
Left option looks to be the GR5
Posted : 30/06/2017 1:34 pm
I've done the GR5 option but not the other. It was a good few years ago now but from memory it wasn't great - quite a wide track which I didn't really feel justified the ride up to the Col.
Posted : 30/06/2017 1:46 pm
[quote=tomtomr ]I've done the GR5 option but not the other. It was a good few years ago now but from memory it wasn't great - quite a wide track which I didn't really feel justified the ride up to the Col.
Aye the fact I can only find the segment as a climb on Strava rather than a descent probably says a lot
Posted : 30/06/2017 1:57 pm
 leth
Thanks Jambalaya. I quickly calculated it at 2.30 to 3hrs.
Alexxx I maybe interested as I'm passing through Morzine a few times this summer & will probably have a few days to myself as I'm meeting people at different times.
Posted : 30/06/2017 7:54 pm
Jambalaya, you posted a video titled Descent of la Bougeouise a year or so ago. Am curious whether the first half of the video is the usual descent ( presumably after the ridge and road hairpins) or whether it is actual the steeper route straight off the top of La Bougeouise. Either way it looks pretty good.
Posted : 30/06/2017 11:11 pm
Re: Col de Cou.
I've only ever ridden up from the Swiss side. I find the climb a challenge and walk it for some of the way. Eating at La Laspisa is wonderful until you get to the climb- a plate of cheese and charcuterie is not the best trail food.
The descent is silly fast and I really enjoy it. The side route via Les Chalets de Freterolle isn't worth the effort TBH. Fiddly and fussy at first, followed by a lovely grassy descent that all too soon hits tarmac.
I'm really intrigued by the GR5 descent down to Samoens. Also, does anyone have any info on the grand Route du Pay Tour du Dent Blanche?
Posted : 30/06/2017 11:23 pm
www.youtube.com/watch?v=haxmytGVpO0
This was the vid I referred to....looking at the maps it looks like it's the descent just off the ridge from close to the top
Posted : 30/06/2017 11:25 pm
@Carlos yes its the ridgeline one as per map Stoner posted.
From memory its fairly fast bumpy singletrack/grass to trees. Then some nice singletrack with hairpins then wooded section with nice rooty bits, gravel track to singletrack to road climb/"transition" to Chantermerle then wooded singletrack past big rocksin video to village for an ice cream / beverage 🙂
Posted : 01/07/2017 10:37 am
We did the descent to Samoens from Col De Joux Plane last week - thanks Jambalaya for the map and notes. Fantastic trail, well worth the effort.
We got a lift back up to the cafe by the lake at the top from Taxi David - number is 0033 (6) 62 25 39 43. He has a multivan and can take bikes in the back, but not sure how many. price was 35 euro.
[url= http://open.relive.cc/wf/click?upn=flHSUXb3xyYxeVtIyAnfN16EyPgn9FivLRONL6FDLP-2BF-2FLG7TukdBvXc2991AaJDyRxPzPbmreqh7nRM5sGeFA-3D-3D_II8y3RTULFYZhiHRT7cX3rmy0Qv1Gkqz3w40fXvWgCVQjTd3uz3Hr-2FRZQyubLyzsE-2BzB0SsxNmxMKDygVwe23PhGUcY4UtgunqBK-2B-2F1t6cmkxiWrzSXl7U9TpFACfB6OSjimMfdS-2BE9UlfL8sPIb6vv7koEOH8cuQPqKA-2BRZzAE3fGB-2BxvXh9kkR2vmRBaaX-2FDkUQ7VzHJqEVSaHKEtk4cCQ9N9HI5q6GG2Vpu-2B3544-3D ]Relive it[/url]
Posted : 01/07/2017 11:13 am
^^ top taxi tip thanks ! I got the route off folks here (freeridenick from SH/Nirvana Cycles freeride) maybe 5-6 years ago so good to share the love
Posted : 01/07/2017 11:15 am
Just a query/ offer. I have a whole bunch (9 I think) of electronic lift passes I'm keen to pass on. Some have bonus points on them too. Free to a good home(s). It would be nice if some cash went into the local Mountain Rescue/ Air Ambulance/ Cave Rescue pot though. Message me your address if you want any.
Posted : 02/07/2017 1:35 am
I'm there 8-22 and being of the XC persuasion with outbreaks of steep stuff I've been hunting for some decent GPx's to load up for 50-100k rides. Any pointers much appreciated as have only Skied out there. Equally if anyone fancies a meet up then let me know.
Posted : 03/07/2017 9:30 am
50-100k rides
unless you're as fit as a butcher's olympic athelete you will fine 50-100km routes entail a lot of climbing unless you just do valley bottom there-n-backs. There are few long distance contouring routes.
You can stitch together vtopo routes (see book linked to earlier).
I dont have gpx Im afraid. you may be able to download some from
Posted : 03/07/2017 9:33 am
I did wonder. Not averse to 2-3000m climbing in a ride - will have more of a hunt then.
Posted : 03/07/2017 9:36 am
I'll be out in August and would be up for the Samoens run (or another one) too.
Has any cunning chap or chapess started a doodle poll for dates and roll call yet this year?
Posted : 04/07/2017 6:11 am
@ade I think Amrose started one
@Phil you seemed to do (mostly) the yellow route not the one Stoner posted (mix of yellow then red)
Posted : 05/07/2017 11:33 am
Just arrived back from a fab week in Morzine.
Did the Essert Romand route as recommended which was great fun. Also rode a descent known as Jenkins in Chapelle d'Abondance. Its in the VTT book...very very steep in places, technical and fun. I think the vertical drop is around 2000'.
There was quite a bit of rain during the week so we headed out to Pila, Italy one day. Here the trails were bone dry. If you get the opportunity you should go...there is an 8k downhill (3000' descent) from Pila to Aosta..all natural in feel, no firetrack, utterly superb. The upper lift at Pila is now open so you can extend this by a further 7k. Its 2hrs to get there but well worth it.
Unfortunately didn't get round to doing the Col de Cou ( Mosettes lift was shut for several days) or some of the other routes discussed but can't complain.
Posted : 31/07/2017 5:23 pm
Yep can confirm the quality of the Jenkins descent, did this a few weeks ago, just what we were looking for, would also say if the point Mossette lift is running the Grande conche DH is a fantastic wild run on the Swiss side, you can then also do the red DH on the crossets lift, all fine on trail bikes and brilliant.
Posted : 31/07/2017 6:32 pm
How does one get back from Chapelle d'abondance? Does the vtt bus go that far or is it a climb up the road?
Posted : 31/07/2017 6:47 pm
We were staying in Chatel, other half to the rescue.
Bus is from the centre of Chatel to the bikepark, would be a bit of a ball ache riding it, but not that far.
Posted : 31/07/2017 7:01 pm
A bit of my own research and it seems there is a bus. http://www.valleedabondance.fr/la-navette-colombus.html
Apparently it has a rack for 8 bikes
Posted : 31/07/2017 7:10 pm
By the way the Chatel to bikepark bus is free.. every 20mins, happy trails.
Posted : 31/07/2017 7:23 pm
We rode back from Chapelle to Pre La Joux on the road. It's probably 6-7 miles at a very slight incline. Have to say in the heat I struggled big time on the last few miles. We covered 50-60km that day. I forgot there was a bus...until I saw one pass with bikes on the back.
Posted : 31/07/2017 7:34 pm
1year on and has anybody ridden the route shown on the map in the 1st post?
Posted : 22/08/2018 2:07 pm
If anyone is interested i did  Avoriaz to Morzinette a week ago, it's fairly good in the second half, ie below morzinette in the woods, initialy thought we were on the wrong trail at the start, a lot of rock gardens/boulders it gets better, so the first thirty  minutes is a push carry.
Also the Col du Cou, Arete route now has no cycling signs, a Swiss walker in no uncertain terms told us cycling was not allowed, we were just pushing through a gate at the time.
Posted : 22/08/2018 2:20 pm
^ Really ? Is that the route on the ridge down to Champery ? I did it 4 weeks ago and there was nothing then.
Posted : 22/08/2018 2:28 pm
Do you mean the map in Stoners post? The order of posts is a bit messed up since the update. That route is the classic samoens route. Great fun and lots of down for little climbing, although you do need to find a way home.
Posted : 22/08/2018 2:40 pm
nickjb - Yes, Stoners post.  After riding Samoens for the day, last month, then driving on to Morzine, I never realised it was SO close, especially when you get to the top of the far lift from Les Gets where the café bar is.  Keen to finally do the ride when I return in 2019 and looks like there are taxi options to get back up.
Posted : 22/08/2018 2:44 pm
Yeah big no cycling sign from the start of the second section by the farm, he pointed to the sign and said this is the sign known internationaly, a red circle with a bike with a line through it, this was two weeks ago.
Another good singletrack descent in that area is Ripaille starts just below the Lapisa snack bar, keep following the track to the chalet (ripaille) then heads to Champery, starts on alpine meadow with lots of cow pats, where you think this is going to be rubbish but then gets really good in the forest.
Oh and this also has a no cycling sign! and it is in the VTT topo book, it does mention that access is sensitive when it was written.
Posted : 22/08/2018 2:51 pm
What could we do, on the Col du Cou route we just took the route marked in the Vtt topo book, a gravel road to Champery, what a waste having come over from France, i didn't want to cause an altercation with the Swiss Walker, two british ramblers also piped in and said bikes were not allowed, in someone elses country i thought it best to be respectful of the regulations, i was with my 17 year old son and didn't want  to set a bad example by ignoring them.
On the Ripaille descent we had ridden over from Chatel thinking this must be legit it's in a book, only to find the no cycling sign, we rode it anyway, it seems environmentalists in Switzerland really are clamping down, anyone else have experience of riding here, surely you can't just ignore the fact cycling is not allowed, i'm all for cheeky in my own country but this is really disrespectful abroad is it not, the guy in the bike shop by the lift just said ride late when there are no walkers around.
Posted : 22/08/2018 8:31 pm
