Following on from my earlier queries....
I have ordered a Hope 34t chainring to bolt to my XT triple cranks in order to try a 1x10 set up. I'll have a 36-11 cassette on the back, will this combo be ok or should I go to a 36t chainring? Suppose it all depends on the terrain?
Also how many bottom bracket spacers do I need to fit to a 73mm shell to ensure the chain ring is central relative to the block?
Can I put the chainring in either the outer or inner position on the cranks?
Ta
34t is fine. unless you only every ride in the 11t sprocket at the back and you spin out
one spacer on drive side
chain ring in middle position
Only put it on the middle ring. Why a 73mm BB? is that the size of your frame? It don't really matter what size chainring you start with within reason as you'll change it if you don't like it.
What chain device are you using?
Also if your changing your cassette are you replacing your chain? If not expect some serious skipping.
Yes changing chain, cassette, shifters and chainrings.
73 is the BB width
I was looking at using a Superstar XCR chainkeeper
Sounds like you've got it sussed young lady.
Good luck and god bless yuh.
Suggests you're going from 9 speed - you know you'll need a rear mech too.
I use 32T front on my 1x10 bike, with an 11-36 cassette. Might be slightly too low, still getting used to it but I'd rather too low than too high. Also pedalling fast makes you look well pro.
I did have 34 on the previous build and I know it's adequate- did a few known Orrible Climbs with it and it wasn't too bad at all. But so far the 32 hasn't been as much of a drawback as I'd expect it would.
Superstar XCR is a perfectly decent bit of kit, but I'd suggest if you can, spend a little more and get the MRP 1X- it doesn't work any better but it's quicker and easier to set up- has very simple chainline adjustment that can be done with the cranks in.
But, also I'd mention that a top-guide alone, unless combined with a clutch mech, isn't quite up to the job. I used to tolerate it, on an older build, but it did drop the chain more often than you really want.
You need to work out where the middle of your cassette is and space your crank accordingly
[url= http://sheldonbrown.com/chainline.html ]Linky[/url]
I now get away without a bottom device, but that's with a bash and short cage saint to help the n gear jump stop.
A friend was just saying today that he is fed up with his seat tube mounted superstar whereas I have had far less problems with my, albeit more expensive, ethirteen...
Oh- yeah, the seattube mounted one is pure mince.
Don't forget to order short chainring bolts!
Charleithebikemonger sells them.
Don't buy the ethirteen single chain ring bolts; you cant put more than 5 nm of torque into them without them stripping. Just doesn't seem safe to me.
Yep the seat tube superstar I could not get on with either. Difficult to adjust with useless grub screws.
Stronglight brand bolts have been fine for me.
