Mongoose Teocali re...
[Closed] Mongoose Teocali rear hub bearing?
Anyone know the rear hub bearing size for a 2011 Mongoose Teocali? WTB Speeddisc rim with a no-name hub! Loose bearing on drive side need replacing, this is achieved by removing freehub body/cassete and inner race seat of bearing is fixed(bolted?)to hub.
Posted : 22/03/2016 10:09 am
best bet is to dismantle and see what's written on the bearing seal (I assume it's cartridge bearings).
Id do the freehub bearings at the same time if I were you.
Posted : 22/03/2016 10:11 am
Mms, it's a mates and I've not seen the freewheel, only the hub end. I'm now thinking that what I'm seeing is the remnants of an inner race of a sealed bearing as opposed to what I was led to believe an open race bearing. Will have to have another look. He convinced me that it was a loose bearing style inner bearing?
Posted : 23/03/2016 8:04 pm
If it's a loose bearing hub then they tend to be a standard size for rear hubs. Halfords do kits that even include the grease you need.
Even if the bearing surfaces in the hub are a bit ropey it's still worth giving it a service and fitting new bearings for three or four quid.
Posted : 23/03/2016 8:42 pm
Cheers was was, we have a good bike orientated Halfords in Dumfries with at least 1 good mech. Will pass on info to mate tomorrow.
Posted : 23/03/2016 8:54 pm
