I have a monarch plus debonair and on the softest compression setting there is a knocking, thud / clunk, approximately half way through the travel, this has only developed over the last day or 2, the problem is not there on the middle or firm setting, and must admit i am a little stumped. I have de-pressurised and pumped up the shock compressing it at intervals, to see if this would fix it but to no avail.
Anyone encountered the same and know of a fix?
Rab
Posted : 29/12/2014 8:15 pm
Have you tried compressing the suspension without the shock attached? Just to make sure it is the shock and not a worn bush or bearing
Posted : 29/12/2014 8:27 pm
Yeah tried that earlier, definitely the shock
Posted : 29/12/2014 8:52 pm
