Modifying an axle, ...
[Closed] Modifying an axle, but which and how?
My dilemma...
My new frame will have a 135x12 through axle rear end.
The hubs I want to use (Chris king single speed) come with 135x10 bolted axle or a 142x12 through axle.
Buy the right width and drill it out or lop 3.5mm off each end of the longer one?
Posted : 18/05/2018 11:02 am
CK hubs have steel inserts on the ends of the axles - it might not just be a case of lopping bits off?
Posted : 18/05/2018 11:07 am
On the other hand, the 135x10 use a 20mm OD axle and are internally threaded at the ends so if you don't need the threading then drilling them out isn't removing that much material overall?
Posted : 18/05/2018 11:12 am
That was my thinking, plus reduces the risk of any trimming of ends being skewiff...
Posted : 18/05/2018 11:19 am
although it introduces the risk of you making the hole in the middle off centre 🙂
Posted : 18/05/2018 11:21 am
couple of adjustable reamers will keep it all square (2mm from one reamer probably too much to expect)
https://www.rdgtools.co.uk/acatalog/Adjustable-Reamers-Individual-HSS---Metric.html
Posted : 18/05/2018 11:23 am
Make sure that you still have sufficient thread remaining before you cut.....measure twice, cut once and all that guff.,
not only the axle overall length, but thread length as well.
Posted : 18/05/2018 12:23 pm
Drnosh, I don’t want any threads left, I’m using a through axle 😊
Posted : 18/05/2018 12:34 pm
