Mini bit driver too...
[Closed] Mini bit driver tool- does this exist?
New shock on the way, minus the official tool http://www.silverfish-uk.com/products/39800525_39800525
I'm not really keen to spend £30 on that. I see the 6mm is cheaper https://activesport.co/epages/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e.sf/en_GB/?ObjectPath=/Shops/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e/Products/398-00-746
However, I have plenty of 3 and 6mm hex bits and was hoping there was a "driver" or thumbwheel style holder (something similar looking to the fox 6mm tool) I could use with them to perform the same job? There won't be much torque required surely..
Posted : 31/10/2018 11:25 am
Cheers. Thinking I may want something without ratchet for this application though- simply a holder..
Posted : 31/10/2018 11:41 am
I have a Bergen one that was about a tenner that ratchets but also locks, can’t think of a fixed one.
Posted : 31/10/2018 12:00 pm
How about a 'universal bit holder' with a knurled end:
And cut the unused end off?
Posted : 31/10/2018 12:29 pm
Can't help but that's a spectacular bit of price gouging by Fox.
Posted : 31/10/2018 12:32 pm
Spot on otsdr!
Posted : 31/10/2018 12:55 pm
 geex
The 6mm plastic tool you linked to is just to hold the outer adjuster still while you turn the inner 3mm separately.
There's a hole in the center of it to push your 3mm through.
You really don't need anything to hold your 3  and 6 mm bits with as the adjusters are very easy to turn.
Posted : 31/10/2018 1:09 pm
 cdoc
