Mineral oil on pads
[Closed] Mineral oil on pads
So, was bleeding my new SLX's last night and got a couple of drops of mineral oil on the pads ๐Ÿ™
The rear now squeals horribly - any way to stop this? I heard a rumour about putting the pads in the oven?
Posted : 23/09/2011 8:05 am
I've done the oven thing before with success
Posted : 23/09/2011 8:09 am
the oven thing (I use a burning pot of meths) does work -ish, if your pad contamination is light. They're unlikely to ever be as good again though. The only real solution is to get new pads and clean the disc with a clean rag and residue free solvent.
Posted : 23/09/2011 9:29 am
I have a similar problem- however I dont think I have got any oil on them! Front brake, only about 4 rides old, is now rather squealy, what else causes this? Had it before when I have done a poor bleed job, but these were working lovely last time the bike was out. Any way to visually check of contamination of the pads?
Posted : 23/09/2011 10:18 am
This is why I always use the bleed block when doing shimano brakes, I have used the cover in solvent and then BURN, BURN! MY PRETTIES! technique before with variable results.
Posted : 23/09/2011 10:23 am
They are infected put em on a hot hob till they stop smoking
Posted : 23/09/2011 10:37 am
Hold with pliers or mole grips etc,then heat with a plumbers blow torch.Don't try to melt them just waft the flame over them till it stops smoking & crackling......
Posted : 23/09/2011 10:44 am
I tried the hot (gas) hob method. Seemed to work, apart from the pad material falling off the backing plate........
Posted : 23/09/2011 10:53 am
