MiFir bottom bracke...
[Closed] MiFir bottom bracket eBay
Took a punt on a Mifir bottom bracket from eBay which is Shimano compatable and I used an adaptor for gxp. Bearings smooth but there is slight play on install using no spacers, one spacer etc.
Its a 73 shell. Roughly 1mm movement on the sram cranks as it does not fit tight enough to the cups.
Any ideas or anyone had similar problems?
Posted : 24/04/2018 9:24 am
