Memorymap help
[Closed] Memorymap help
I have a mac. I have an old Garmin etrex which comes with a serial port based cable to connect to a pc (which died some time ago).
I have the serial-usb cable.
What settings to get memory map to comunicate with my old tech??
Posted : 26/11/2010 12:11 pm
 Rip
You'll need to install the drivers that came with your USB-Serial adaptor. Memory Map should then be able to see the Etrex.
Posted : 26/11/2010 12:36 pm
+1 Rip - but you also need to set the baud rate etc on MM IIRC? Or I think it has a drop down list for model numbers?
Posted : 26/11/2010 12:38 pm
