Memory Map v5 - Rou...
[Closed] Memory Map v5 - Route Card Advice
Plotted out a route on the above.
Thought a route card would be useful. However, it displays every single waypoint ๐Ÿ™ Which is naff.
Any workarounds can routes be used ? But cant add marks to the or waypoints to route ๐Ÿ™
Any thoughts ?
Posted : 08/09/2011 2:47 pm
I think I solved it it now.
Too many waypoints in the first place.
Posted : 08/09/2011 2:54 pm
You can get it to only use named waypoints (ones you have named yourself) in the route card so you can still have a 'proper' route shown but with only certain, named points included
Posted : 08/09/2011 3:07 pm
The best option is to convert it to a track - click on the route anywhere (but not on a waypoint, right click, operations, convert to track.
Then I select the track again, right click, properties. I set the line width to very thick and the transparency to 50%.
This gives a nice simple track that you can still see the map details through.
Posted : 08/09/2011 3:30 pm
I came to the same conclusion as Graham.
Working on a route card template now. Anyone know how to do a the a cumulative total ? like the MBLA route cards.
Posted : 08/09/2011 5:54 pm
