Maxxis: What width ...
[Closed] Maxxis: What width Advantage comes up the same as a 2.35" High Roller?
Just wondering, as the tyre sizes are different etc. Any feedback on whether this is a good combo also appreciated. It would be run 3-seasons, possibly changing to something faster June-August if I can be bothered.
Posted : 30/11/2010 6:17 pm
not the 2.4" - they're MASSIVE!
advantage tyres aren't great in wet slippy muddy conditions, not bad, but not great.
Posted : 30/11/2010 6:22 pm
 GW
possibly none! but run a larger front tyre anyway.
Ok... to try and extract the maximum useful information from the STW masses...
What width Advantage comes up the same as, or slightly smaller than, a 2.35" High Roller?
๐Ÿ˜€
Posted : 30/11/2010 6:25 pm
can you get a 2.2"?
Posted : 30/11/2010 6:27 pm
They come in 2.1", 2.25" and 2.4". I know they are comparitively WIDER than High Rollers, so I guess its a choice between the 2.1" and 2.25".
It's possible that the 2.25" is bigger for all I know.
Posted : 30/11/2010 6:30 pm
no, they're bigger than high rollers.
a 2.4" advantage is much, much, much, bigger than a 2.35" H-R.
Posted : 30/11/2010 6:33 pm
Arse, I meant wider. Edited.
Posted : 30/11/2010 6:34 pm
The 2.25 is noticeably bigger than the 2.35 HR. I think they're fast enough to be ridden throughout the summer and manage fine in the winter (but, as above, aren't the best in really muddy stuff).
Posted : 30/11/2010 6:35 pm
2.25" a touch bigger, if anything than a HR 2.35"
20% off pairs!
http://shop.18bikes.co.uk/products.php?plid=m11b0s399p0&tbv=_WHEELS_Tyres
At risk of being ridiculed for providing a sensible and hopefully useful answer:
On the P7 I run a 2.35 HR on the back and a 2.25 advantage on the front. Personally I love it and find the front end grip superb on the corners. They also roll much quicker than I expected. The 2.25 advantage is [i]slightly[/i] narrower than the 2.35 HR, but hardly noticable.
Rob
EDIT: I obviously type much slower than other sensible people ๐Ÿ™‚
Posted : 30/11/2010 6:37 pm
tandemwarriors - perfect answer. Please accept my sincerest thankyous.
Posted : 30/11/2010 6:39 pm
2.1 a bit narrower, but not a lot. My fav all condition tyre. Run them a little bit soft as the volume is quite big.
And I like them in soft/loose conditions because of the grippy side knobs. Agree they are not the best at straight-line digging into slop tho. But the low centre knobs is why they roll well.
Posted : 30/11/2010 6:52 pm
As per other posters, for the same width of rim, 2.25 Advantage is slightly wider than 2.35 HR, 2.1 AdV is slightly narrower.
Posted : 30/11/2010 7:04 pm
Only problem is it is wrong i'm afraid.
A 2.35 high roller on a dt5.1 at 35psi is 52mm across the carcass not including knobs. A 2.25 advantage is 56.5mm measured in the same way.
HR on the front and advantage on the back works for me. Certainly less drag than vice versa.
Posted : 30/11/2010 7:10 pm
Sometimes every millimetre matters.
Posted : 30/11/2010 7:39 pm
I run a 2.35 HR front and 2.1 advantage rear, the advantage is only just smaller than the HR
I can tell you a 2.25 Ardent is definately wider and higher volume than a 2.35 HR, but you didn't ask that
Posted : 30/11/2010 7:42 pm
I ran a HR 2.35 back and front, recently changed to an Advantage on the back. It comes up a little bit wider and I think gives less rolling resistance.
Was out in pretty muddy woods recently and thought they were poor in that but pretty much everything else has been very good.
Posted : 30/11/2010 7:51 pm
