Maxxis Ardent EXO 2...
[Closed] Maxxis Ardent EXO 2.25 run tubeless on Stans Flow EX - any issues?
Anybody using a Maxxis Ardent EXO 2.25 tubeless on Stans Flow EX?
Just wondering if there are any issues with them blowing off the rim or leaking/burping air?
Posted : 19/07/2013 2:48 pm
 hora
I can't help on Stans but I'm running Ardent EXO's on DT Swiss 6.1 which is supposed to be nye on impossible to make tubeless- the Ardents are quite 'tight' and really grip/a bugger to unseat if required. So I think you've got the best non-tubeless tyre for the job IMO.
It blew straight up - no hassle or soapy water first time.
Posted : 19/07/2013 2:49 pm
Im using the standard 2.25 Ardent on Flow EX (front)
Went up tubeless a treat, not a single leak. Had no issues with them at all.
Posted : 19/07/2013 2:50 pm
Not an Ardent but a Minion EXO on Flow. Was a bit of extra work to get it seated but got there in the end.
Posted : 19/07/2013 2:52 pm
I was running 2.25 & 2.4 Ardent EXO (f & r) on a set of Sun Ringle Chargers (licenced Stan's tech, similar to Flow EX).
They were fine in the UK but I burped front and rear massively in the Alps last week.
Seem to be ok with tubes in ๐Ÿ˜‰
Posted : 19/07/2013 2:54 pm
I'm running Ignitors EXO on Crest and they fine. no problems at all.
Posted : 19/07/2013 3:20 pm
I'm running that exact combo on the rear of my Blue Pig. No problems other than the rim was a pain to tape up as 25mm rim tape isn't wide enough.
Posted : 19/07/2013 6:47 pm
Posted : 19/07/2013 6:49 pm
No problems
Posted : 19/07/2013 7:51 pm
I have one.. it was so hard to inflate tubeless that I got my 4 year old daughter to blow it up with a track pump.
I run it with a st minion dhf and they work well for me
Posted : 19/07/2013 8:01 pm
First set of them I tried the air just leached through the sidewalls something rotten to the extent I took them off and only use them on tubed set up.
Obviously other folk have not had the same issues.
Posted : 19/07/2013 9:20 pm
 Alex
Hmm I had that tyre on my EX rims and it didn't go well in the rocks of tenerife last year. Ended up having to put a tube in it. It's absolutely fine on a set of flows but on the Arch EX I gave up with it after it parted company with the rim a few times.
Posted : 19/07/2013 10:08 pm
