I have a large enduro year 2015/2016 and want to change the dropper out for something with a bit more travel. Before spending a couple of hundred plus on new post what posts fit when fully inserted in the frame as currently need to drop my seatpost all the way into frame to get preferred riding position. Looking at highline 160 and fox transfer 150mm as preferred options
Depends how long your legs are
You need the current version of this
[img]
[/img]
Or the measurements of what your looking at
then it's just measure how far you can put a seatpost into your frame before it jits something. Rest is how much is exposed at full extension for pedalling.
Revive dehy has the lowest stack height of any post. I fitted a 160mm drop in the same space as a 125mm reverb.
Interested in this too, (2016 stumpy), does anyone know which cables will fit through the internal routing without drilling the holes?
I think the revive will fit. Just wanted real life experience of what people have managed to fit in as what is written on paper doesn't translate to real life sometimes
