Mavic wheels back f...
[Closed] Mavic wheels back from the menders but is all ok.?
Sent my rear Mavic ksyrium off for a warranty job (vibration and noise @ 30mph+) and upon return they now have a quiet freehub. Before they went they made the usual mavic clicky freehub noise.
Would I be correct in thinking that the freehub has been packed with grease and would I be also correct in thinking that the freehub should have mineral oil in there for lubrication not grease.
Posted : 20/10/2014 2:23 pm
Mavic recommend five drops of their own brand oil in the freehub.
Posted : 20/10/2014 2:27 pm
Yes, defo mineral oil
if its been returned to the Service centre then there's no way Gary would have put grease in, a really fresh well oiled hub might not be very clicky though
Posted : 20/10/2014 2:28 pm
they come with minimal grease/mineral oil as standard so they have that "wow clicky/low friction feel"
as you have found out that if you dont service and renew this oil/grease regularly they wear out - probably just the main ptfe bush.
they will have stuck a bit extra in , it will bed in most likely.
hopes are the same after a service.
Power hose it good. She'll soon be clicking again.
Need to do mine - is Shimano brake mineral oil good stuff to use?
Posted : 20/10/2014 2:38 pm
From what I have seen on the tinternet it is supposed to be ok to use.
Posted : 20/10/2014 2:44 pm
