Mavic TN719 and Sta...
[Closed] Mavic TN719 and Stans Tubeless
Will Stans work with the TN719?
Thanks
Posted : 15/09/2011 1:36 pm
Anyone?
Posted : 16/09/2011 8:19 am
Works fine with the rim strip, as does a few wraps of insulating tape
Posted : 16/09/2011 8:20 am
Yep no problems here.
Yarse. Fully tubelessed using TN719 and electrical insulation tape.
Posted : 16/09/2011 8:24 am
Thanks!
Posted : 16/09/2011 8:26 am
when using electrical tape, how many layers did you use and what valve did you fit?
Posted : 16/09/2011 9:45 am
2 layers all round and an 3rd overlapping the valve hole. I use the [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=49695 ]Effetto Cafe Tubeless[/url] valves, work well but a bit spendy I thought. Previously used the [url= http://www.pedalon.co.uk/acatalog/bontrager_ust_valve.html ]Bontrager Valves[/url] on my 26er but that was with a bontrager rim strip, which worked really well in Bontrager rims.
Posted : 16/09/2011 10:25 am
^ ta
Posted : 16/09/2011 12:34 pm
Thirded. Works just fine here too.
Posted : 16/09/2011 12:41 pm
did you pit the leccy tape straight onto the rim or ontop of rim tape.
I had thought about coating my velox rim tape with some sort of polyurethane / tubless latex fluid
Posted : 19/09/2011 9:34 am
Straight on rim
Posted : 19/09/2011 9:50 am
I've used the valves cut out of an old inner tube, work fine. Just make sure they have removable cores to make them easier to inflate.
Note that specialized do tubeless valves now but they don't have removable cores, crazy.
Posted : 19/09/2011 9:55 am
All Schraeder vales will have removable cores
Posted : 19/09/2011 9:57 am
Another question on this. Will [url= http://www.wiggle.co.uk/stans-no-tubes-bontrager-29er-tubeless-kit-1/ ]Stans No Tubes Bontrager 29er Tubeless Kit[/url] work on my Mavic TN719's or is there something different about Bontrager rims?
Posted : 28/09/2011 12:08 pm
Quick bump for someone to put me off before I hit the buy button
Posted : 29/09/2011 7:04 am
Seems expensive but the Q&As say it's universal
Posted : 29/09/2011 7:11 am
