Mavic rims, tyre pr...
[Closed] Mavic rims, tyre pressure info.
 PJay
Mavic used to publish info. on their website relating to recommended tyre pressures for a given width of tyre for their rims (lower maximum pressures for wider tyres). I've just ordered a wider set of tyres (2.1") to go on my XM719 rims and popped back to the Mavic site to check the Max. tyre pressure for a 2.1" tyre and I can't seem to find it. Has it gone or am I looking in the wrong place?
Posted : 14/07/2009 4:18 pm
You won't want to go anywhere near the max pressure anyway, surely?
Posted : 14/07/2009 4:20 pm
 Olly
ive put UltraGatorskin 26" roadie tyres on my 717s at 120psi and had no problems.....
Posted : 14/07/2009 4:23 pm
Ah - if it is road tyres then I get the question (but 2.1?). Rim tape quality is much more of an issue than rim itself it that case.
Posted : 14/07/2009 4:27 pm
 PJay
I thought that larger width tyres put more pressure on the rims and had markedly lower max pressure ratings. I run mine reasonably high as they're semi-slicks and do a mix of on/off road (probably 50psi-ish).
Posted : 14/07/2009 4:49 pm
