Looking for some set up tips for my DUC32’s. I guess I want to reduce the compression damping, to give a more linear, plush feel, without reducing the air pressure and increasing sag. At the moment it is all set up as standard; shims in their normal order and 5WT oil. Anyone have any set up tips or is it just changing the shim stack around that I can try? What about the air pressure in the damping leg?
Have you tried this:-
[url= http://www.maverickbike.com/cms_images/file_8.pdf ]Maverick tuning chart.[/url]
Yes, seen that but it's not particularly helpful. It only talks about rebound, not compression. Which seems strange as there is a rebound dial on the top. I understood that the shims changed the compression damping...
I'm about 170lbs so the standard set up should be ok, but I feel it needs to be a bit plusher. If I take any more air out though though it feels too low.
Sounds like you need to change the shim set up, email or call me and I'll let you know how to do it.
Craig
simpsonscycleservices@googlemail.com
