Massively confused ...
[Closed] Massively confused by hub widths
Long story ... I've a Ribble CGR AL e (the e standing for electric, don't judge, it's great commuting) that I'm adapting during the winter to work on a (wheel-on) turbo trainer.
The Ribble uses the ebikemotion read hub/motor which has a 135mm width, I guess for wider frame compatability. The rear spacing on the frame is therefor an unusual 135mm QR type fitment, with the ebikemotion hub bolted in place. Odd as the non-electric CGR is 142mm thru axle I believe, anyhow I digress...
So I'm trying to find a replacement rear wheel, as switching it out will remove the electric'ness and give me a normal gravel/road bike of sorts to work on the trainer. The bike came with a set of Mavic Askium Elite Disc rims, which are OK, so I hunted the same thing, but am I right in thinking that road hub spacing is 130mm QR or 142mm thru axle?
Do I therefore instead need to hunt out a 29" (700) mtb style wheel instead that is QR compatible still? The challenge however is finding one not too wide so it takes the skinny trainer wheel.
Or have I got it wrong and road disc hubs are 135mm? And it's rim brakes that are 130mm?
Posted : 04/11/2020 3:58 pm
A 142mm TA hub is just a 135mm QR hub with different end caps, if that helps?
Posted : 04/11/2020 4:01 pm
I thought 135mm was the standard MTB rear when qr’s were the norm
Posted : 04/11/2020 4:06 pm
Isn't this the standard that was used for yonks before TAs came along, and still is on lower end bikes?
Yes, sorry, I mean unusual in that it's not thru-axle, rather than the size as such.
https://www.bike-components.de/en/Mavic/Aksium-Wheelset-p66638/
I'm confused by the specs on the above as it mentions: "Over Locknut Dimension: 10 x 130 mm quick release".
Is that because they are rim brakes and not disc?
Posted : 04/11/2020 4:11 pm
How about the easiest. Measure OLD of wheel you are kicking out and use one with matching hub sizing for analogue version?
There is very few available 130mm Disc hubs/wheelsets on the market. Mainly available as OEM stuff. Personally seen only some Bontrager numbers and 1 aftermarket hub - BLB Via
Cheers!
I.
Posted : 04/11/2020 4:15 pm
Road disc frames are 135mm QR or 142x12
130mm is only for rim brake road bikes.
Posted : 04/11/2020 4:17 pm
The old wheel is definitely 135mm, and the frame is 135mm when I measure it with a steel rule.
It's more about ensuring the replacement I buy fits.
Posted : 04/11/2020 4:18 pm
Thanks Horatio, that's the conclusion I was getting to, in a muddled way.
Posted : 04/11/2020 4:19 pm
Or have I got it wrong and road disc hubs are 135mm? And it’s rim brakes that are 130mm?
This
Posted : 04/11/2020 4:55 pm
Yup, I was under the impression that only road/rim/QR was 130mm and that road/disc/QR had moved to 135mm for parity with MTB.
Posted : 05/11/2020 7:13 am
https://www.cyclestore.co.uk/mavic_aksium_disc_road_rear_wheel_2019-ID_76920
Shouldn't be hard to find what you neeed. These come as thru-axle but with QR adaptors.
Posted : 05/11/2020 7:35 am
