Marzocchi Maxle - D...
[Closed] Marzocchi Maxle - Doesn't undo just spins
Hi
Never seen this issue before. And no I haven't over tightened the Maxle!
The insert into which the Maxle goes into is just spinning. Anyone had this happen?
Thanks
Henry
Posted : 15/12/2017 11:00 pm
If the fork legs are getting wider apart as you try and unscrew it then the axle is probable corroded to the hub bearings.
Posted : 15/12/2017 11:06 pm
What fork?
Posted : 16/12/2017 2:14 pm
