Has anyone got these forks?
I'm mightily confused by what adjusters these should have.
Got a set from Wiggle and they have:
One compression adjust on bottom R leg
Rebound and air on top of R leg
Blanking stopper on top L leg that does not turn.
Is this correct?
Pics here indicates adjuster on top L leg too:
http://www.wiggle.co.uk/p/cycle/7/Marzocchi_44_RC3_Ti_QR15_Suspension_Fork_2010/5360048059/
http://www.marzocchi.com/Template/detailProdotti.asp?LN=UK&idC=1592&IdFolder=113&IdOggetto=56789#
However Wiggle say these pics is a pre-production model and that the high/low compression adjust is combined into one adjuster, the R leg one.
Hmm.
Anyone else got these and can confirm what they should have?
Ta!
Top coil side leg has air preload, rc3 damper side has high and low compression on bottom, top has air chamber for increasing oil volume.
I think anyway!
OK cool.
I was under the impression that it had separate low speed and high speed compression adjust but maybe I'm confused. Descriptions aren't that clear!
All my adjusters are on the right leg though. One compression on bottom and rebound and air preload on top.
have they only got the 1 air chamber then?
But yes the little red compression dial does both high and low speed.
Yeah, it's a coil fork with an air preload top-up.
OK, if there's only one compression adjuster, then that's cool.
Cheers!
Yeah the coil forks sometimes still have 2 air chambers, but if its only got 1 they must have dropped the one which controls oil volume in that fork.
Nice. Ta!
