marz 2010 55's
[Closed] marz 2010 55's
 jedi
[#2087951]
is there a hard ride kit available?
i cant find info on it 🙁
Posted : 14/10/2010 5:12 pm
 jedi
anyone?? 🙁
Posted : 14/10/2010 6:13 pm
 ianv
I think that if you need it harder you have to use the air pre load thing. I seem to remember someone on here saying they had been on to the distributors and they were told no other springs were available.
Posted : 14/10/2010 7:16 pm
 jedi
There is no air preload. Just rebound and regular pre load
Posted : 14/10/2010 9:15 pm
Call TF Tuned. The '08 and later 66 can use springs from a Rock Shox - Lyrik if I remember rightly - although some fettling of the spring spacers is required as the RS spring is tapered over the last couple of cm. If there's an RS alternative for the 55, it's possible that the guys at TF will know.
Posted : 14/10/2010 9:27 pm
EDIT It's the Domain fixed-length (non U-turn) spring for the 66, not the Lyrik.
Posted : 14/10/2010 9:43 pm
