Mary Townley direct...
[Closed] Mary Townley directions
 D0NK
I've been told the MTL is well signposted and trail centre-esque easy to follow. Can anyone confirm? I don't have OS maps just a rough printout of the route, do you reckon that's enough?
Oh yeah and is the general consensus clockwise or anti?
Posted : 24/08/2009 1:53 pm
Pretty much. You need to keep your eyes skinned for the signs at times but a man of your wit and intellect should be ok.
Clockwise for me, btw.
Posted : 24/08/2009 1:55 pm
print [url= http://www.idonohoe.com/mary_map_580.htm ]this map[/url] out and take it with you just in case?
it is well signposted, but its not unknown for people to miss a turning
Posted : 24/08/2009 1:57 pm
 D0NK
Cheers Simon.
Thats the rough map I have thanks twinkly, doesn't look to hot in B+W tho.
Posted : 24/08/2009 2:00 pm
When are you going, just out of interest?
Posted : 24/08/2009 2:01 pm
Anyone got a .gpx they could ping me?
Posted : 24/08/2009 2:15 pm
oh ok, you'll be reet with that map and some nouce ๐Ÿ˜‰
(as a guide; if you've not ridden up something steep or very long for 5 minutes, you've gone the wrong way...)
Posted : 24/08/2009 2:16 pm
 D0NK
tomorrow if I can motivate myself, otherwise I'll do the 3towers. Why you up for a spin round MTL?
Posted : 24/08/2009 2:18 pm
Just wondering. I am working all week (just for a change) but I feel like I should get some miles in before Kielder.
Posted : 24/08/2009 3:34 pm
Clockwise and it's reasonably well signposted, just be careful where the Pennine Bridleway heads off towards the Peaks. In last years challenge someone ended up on the southern side of the M62.
Having said clockwise a mate of mine said he's just ridden anti-clockwise in preparation for this years challenge and thought it was easier that way. To qualify that though he finished last year in 4hrs 50 mins so his easy and my easy aren't usually in the same country yet alone the same trail.
Posted : 24/08/2009 3:38 pm
I have the proper map which is basically that but laminated.
Not much use though really is it. I would have been up for this if you [sulking] ever bothered to gove me enough notice about your weekday rides[/sulking]
[happy] it would kill me anyway[/happy]
Doing it on your own?
Posted : 24/08/2009 3:43 pm
 D0NK
Pick a day early september and we'll sort something out ๐Ÿ™‚
Yep, tho currently the weather is pushing me towards 3towers instead, similar distance but no need for time consuming map checks and less gates ๐Ÿ™‚
Oh and cheers for the info everyone
Posted : 24/08/2009 3:54 pm
4/5/6th th sept
I am doing coast to coast 15th /16 th so not too near that or immenent baby dropping?
Any use?
Lowey was also keen on doing this will see if he is free.
Assume it is ok on hardtail (weight saving) anyone?
You taking the Santacruz to even things out?
Posted : 24/08/2009 4:01 pm
 D0NK
STW lee quarry ride the 6th, will mail you about the rest.
Posted : 24/08/2009 4:04 pm
oh yes good point
Posted : 24/08/2009 4:06 pm
oh yes good point
What about the Rossendale challenge on the 13th Sept?
Posted : 24/08/2009 10:26 pm
 D0NK
Well that sucked, I found an mmo route of the MTL and printed out a big detailed map. It was wrong, it took a slightly different route to the MTL in a few places and a completely different route on heptonstall moor. So when the MTL signs did get thin on the ground and I needed a map check I often wasn't where the map suggested I was and took a wrong turn - yes this could have been solved by double checking the map before I set off but MTL = MTL I'd have thought. Anyway I figured out what was wrong halfway round and used the map as a rough guide from then on and did OK. Will try to figure out where I got this mmo from and have a moan at the creator.
Official signage is mixed, in one rat run with no turn offs there were loads of signs in other places like open moorland with loads of turn offs there was only a sign every 2 miles or so.
Posted : 26/08/2009 10:03 am
