See some cheap
Anyone know if they can be lowered like the pros as 120 would be too much
Bump
Thought there was only pro or expert in the towers.
These look like OEM
Infos:
Federweg: 120 mm
Federung: TS Air
Einstellmögl.: Rebound / Lockout extern / Federung per Luftdruck
Gabelschaft: Aluminium, Tapered - 188mm
Gabelkrone: Aluminium
Standrohre: 32 mm, Aluminium, reibungsarm anodisiert
Max. Scheibendurchmesser: 210 mm
Laufradgröße: 29"
Gewicht: 1950gr
Fair bit heavier than the expert or pro
And as these are tapered and I'd need to fit an external cup 120mm would mess with my bike too much, I'd prefer 80 or 100
Who are the uk importers for manitou
Hotlines.
Manitou tower pro forks here. Cheap off CRC, when my fox were out of warranty and cost more to replace creaking CSU and service, than tower pro cost.
Very impressed with manitou, structurally much stiffer, better damper, much more controlled, worth the small weight penalty.
Yep, as good as rockshox, better than fox, not as good as old marzocchi. Just not fashionable.
Been very pleased with mine. Stiff, well damped and seem well built.
Are they still much plusher than others? Steel legged Manitou Six's with the grease nipple [ooh-eer] had next to no stiction, they make my Pikes feel downright clumsy and clunky [even when the Pike's didn't have a shedload of dirt inside them].
[See, sometimes I [i]do [/i] use this forum to talk about bikes! Next thing I'll even go and ride one.....
Naaaaah. ]
Here's the psa
http://singletrackworld.com/forum/topic/psa-29er-forks-cheapo
Not sure if they are steel stanchions
Aaah, sadly they are 29". Also, gold stanchions mean Ally - which is much lighter, but yeah, the old steel ones were smooooth.
