making a 3x9 a 1x9 ...
[Closed] making a 3x9 a 1x9 for racing
I have a SLX triple
how easy is it to make it a 1x9 setup?
I'd like a nice simple setup - would it be best to buy a single spider for the crank and a chain catcher?
then check if the chain needs any links removing.
Posted : 20/11/2013 11:03 am
Very easy.
Just take off the big and small ring. Replace the middle ring if you want a different size. Fit a chain guide. You should be able to remove a few links from the chain too.
Worth considering getting one of the new NW chainrings and a clutch mech and not bothering with a chain guide (with a new mech probably about the same price as a decent guide.) I've been very impressed with mine.
Posted : 20/11/2013 11:16 am
You will also nee single chainring bolts to replace the ones you will have on currently
Posted : 20/11/2013 5:40 pm
Clutch mech not an option with 1x9, if you're buying a different ring I'd get a narrow/wide one anyway, may as well, and pair it with a top guide.
Posted : 20/11/2013 5:46 pm
njee20 - Member
unless you do the simple spacer mod of course (and run a Shimano mech with a 9sp Sram shifter)
Posted : 20/11/2013 5:48 pm
roughly how much weight will be saved going 1x9 (with chain catcher)
Posted : 21/11/2013 10:41 am
can anyone guess how much weight this would save?
Posted : 26/11/2013 9:44 am
7
Posted : 26/11/2013 9:59 am
I'm running a Works Components Fat Wide ring on a 9 speed non-clutch mech drivetrain, no chain device and have had no issues with losing the chain.
so you lose weight of shifter, cable, 2 chainrings, one set of chainring bolts and the weight in the difference in length on the shorter ones you use for the new 'ring. Chain can be a little shorter too.
Posted : 26/11/2013 10:01 am
150-250g ish.
Posted : 26/11/2013 10:12 am
Looks good!
I do worry about the chain on the lowest & highest cogs - he chain will be at an extreme angle...doesn't this destroy the drivetrain?
Posted : 26/11/2013 4:18 pm
