Magura Laurin - Tra...
[Closed] Magura Laurin - Travel Adjust doesn't adjust
Hello,
Anyone got laurins or know about the 130-100mm lock down mechanism? Mine doesn't hold the forks down 9 time out of 10 and if it does, then it slowly rises.
Would like to be able to have a dabble and get it sorted!
Posted : 18/05/2010 10:15 pm
Bump bump!
Posted : 19/05/2010 9:32 am
 RicB
Im assuming you have a laurin fcr? Travel adjust attaches to top of left leg?
The seals can dry out. Try leaving the bike upside down with the travel adjust lever propped open. This will hopefully mean oil dribbles back through the open air piston and sits on top keeping the seals lubed
Magura uk are very helpful if you call them....
Posted : 19/05/2010 10:28 am
Yes, they are FCRs. I'll try what you suggest and see what happens. Not sure how to prop the valve open though, I don't have a cable attached, but will work something out.
Posted : 19/05/2010 11:54 am
 RicB
I suppose the other option is to remove the top cap (let the air out obviously!) and squirt 5ml of 5 or 10wt oil in
holding the travel adjust lever open for 15 mins will probably be enough tbh if leaving overnight is tricky
Posted : 19/05/2010 12:03 pm
How do you remove the top cap? I was trying to do that the other day but couldn't work it out. The FCR dial has a bit of play in it, compared with the Albert Select knob and I wanted to have a look at sorting that out as the dial doesn't snap back the way the Albert Select one does. Think it just needs a good clean.
Anyway, there seems to be a nut over the air valve that might release it, but I can't get a socket over it as there isn't any room.
Any ideas?
Posted : 19/05/2010 1:05 pm
