Magura Julie fluid?
[Closed] Magura Julie fluid?
A mate at work has just got his B2W mtb today from Chain Reaction. The rear brake needs bleeding.
We are wonderng if it is possible to use a standard mineral oil e.g. LHM (like shimano) to bleed them? Is magura "Blood" special in any way?
Thanks.
Posted : 19/02/2010 1:46 pm
'rear brake needs bleeding' ? really ?
to answer your question, magura will tell you to use their royal blood, but in practice standard mineral oil will do.
Posted : 19/02/2010 2:24 pm
might be worth letting it stand for a bit and seeing if it settles down - could just be some air that's moved aroudn in transit.
Posted : 19/02/2010 2:25 pm
Job done. It did need bleeding. Used LHM+
Posted : 19/02/2010 3:54 pm
