Magura Hydro Stop M...
[Closed] Magura Hydro Stop Mountain and HS33 compatibility ?
I bought an [url= http://www.tartybikes.co.uk/product.php?product_id=10934&keywords=evo2 ]Evo2 adapter[/url] to fit an ancient Magura rim brake to the rear of the new tandem (did I mention we've got a tandem ?).
I thought all Magura cylinders were the same size, but it looks like the Hydro Stop Mountain I have got is too small for the clamps on the adapter.
I'm about to bid on an old [url= http://www.ebay.co.uk/itm/MAGURA-HS33-Rim-Brake-Not-Shimmano-Hope-Disco-Brake-/221173361715?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item337ef5ac33 ]HS33 on ebay[/url].
Can someone confirm that this one will fit before I do please ?
Posted : 10/01/2013 1:08 pm
Think the size has stayed the same since they have been called hs33 and it was the earlier stuff that had smaller pistons.
So that eBay one should fit the evo plate just fine
Posted : 10/01/2013 1:15 pm
OK, thanks.
I thought it would, but I thought I'd better check as the levers look different.
As long as the cylinders are the same diameter, that's all that matters.
Posted : 10/01/2013 1:56 pm
 JoeG
Magura has updated the levers for the HS33 once or twice. I don't know if anything really changed or if it was just a styling update.
Posted : 10/01/2013 8:22 pm
