Magura adjustable t...
[Closed] Magura adjustable travel?
 nuke
Is the travel adjust just the upper and low travel lengths eg for the Thor either 140mm travel or, with the handlebar lever engaged, 100mm with no adjustment for any travel length in between.
I assume that the axle2crown height drops down when its at 100mm?
Posted : 04/02/2010 7:30 pm
I've only used mine on one ride so far but yes it is 140mm or 100mm, and the axle to crown length does reduce.
Posted : 04/02/2010 11:14 pm
 nuke
Thanks hamish
Posted : 05/02/2010 8:53 am
