Hi - pinged a spoke. Contacted mavic and they only sell spares in half wheel sets, at about £35 a set
Anyone happen to have any knocking around? It’s the drive side rear I need , but would also like the non drive side / front ones as spares (these are the Same)
Happy to pay obviously
Thanks
Part numbers below
Front and Rear NDS
V2384201 - KIT 12 FT/NDS XA PRO CARB 29'' BTD SPK 289mm
Rear DS:
V2384101 - KIT 12 DS XA PRO CARBON 29'' BTD SPOKE 287mm
Will this turn into a thread of
"If you can't afford spokes for a carbon wheel set"
🙁 sorry I know not helpful
Perhaps not helpful, but if you want to go halfs of a set, I probably should acquire a few because they'll soon become obsolete.
On another note, do you know if Mavic ever made a boost adapter for these wheels?
Hi
Apparently they come in two forms
-135 that can go to 142 with supplied adapters
-142 that can go to 148 with supplied adapters.
Unfortunately mine are the former so I can’t use them boost
Steve
@ continuity. Yeah that sounds an idea. I'm 99% sure the longer ones will work even for the drive side (there's another thread on this). I'll PM you
I know it's a half set only, but if one spoke has pinged I'd be expecting others to follow as they will all have been subjected to the same fatigue.
Its £35 at the end of the day, hardly going to break the bank (I'd hope).
